jerem0621
Sequatchie, TN
Every time a post like this comes along it makes me want to kiss my 5.4 gasser.
Op I hope this works out for you.
Thanks
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
45Ricochet
North Idaho
me2 wrote: I took this picture the day after I bought the truck.
That lump of iron in the bed is a very low mileage Cummins 6.7
I've put over 15,000 miles on it stock since. I was beginning to wonder if it was such a good idea to swap the Cummins in at all. I knew that it smoked once in a while and when I changed oil there was fuel in it. I thought it was a leaking injector and a simple warranty claim would fix it.
I'm in total shock right now.
The moral of the story is that Ford builds great trucks and really chitty engines.
Through the whole 6.0 debacle, I blamed International. I did a double take when the 6.7 came out. As far as I am concerned, International isn't the problem. Ford is.
DON'T EVER BUY A FORD DIESEL TRUCK WITH AN ENGINE STARTING WITH "6". (6.0, 6.4, 6.7)
Now that right there is funny. You know the Ford with a spare tire, err engine. I remember when you bought the Ford and in about post #3 you said you had the 6.7C just in case. You were right!
Quite a few Forge's running around my neck of the woods.
Hope your plumbing is better than this guys.
Good luck
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
fla-gypsy
North Florida
I love my Ford 6.8L V-10 gasoline engine. I believe it is the best motor I have ever owned. Otherwise I have nothing to add to a Ford bashing thread. BTW, I have a buddy rebuilding a 5.9 Cummins engine with only 50k on the clock because the injectors failed and the rings cracked in 3 cylinders.
coolbreeze01
Redding, Ca
No insurance. OK.
Was the truck serviced at a dealer from the beginning? If the fuel filters were changed regularly, I don't see how Ford could deny the claim.
Anyone else ever see brand new parts with rust? It can happen.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
NewsW
US
Something about this case file doesn't add up.
me2
Wherever
NewsW wrote: Something about this case file doesn't add up.
I'm here to answer any questions you may have. Nothing to hide. Fire away.
NewsW
US
me2 wrote: NewsW wrote: Something about this case file doesn't add up.
Not pointing finger at you.
I am not sure you can answer the questions I have.
I need the previous owner / operator.
Right now, I smell biodiesel or contaminated fuel, no proof, of course, only a hunch.
me2
Wherever
coolbreeze01 wrote: No insurance. OK.
Was the truck serviced at a dealer from the beginning? I am the second owner and I have no service records.
Quote: If the fuel filters were changed regularly, I don't see how Ford could deny the claim. Welcome to the world of owning a Ford diesel.
What I do have is a list of every time this truck went to the dealer for warranty work. And the fuel system wasn't touched. The exhaust up pipes were, so the cab has been off once already !
I asked the tech if a service light was ever logged for water in the fuel. It turns out the ECM doesn't log those issues. Hmmm...
me2
Wherever
NewsW wrote: me2 wrote: NewsW wrote: Something about this case file doesn't add up.
So why aren't we reading about 100 other trucks needing the fuel system replaced because of "contaminated" fuel, about which half are Dodges and Chevs ? And Freightliners and Peterbuilts for that matter ?
jerem0621
Sequatchie, TN
NewsW Please don't stir this pot too.
This is flat out a problem with Ford's Diesels, rather, Fords inability to stand behind their product rather than deny deny deny claims.
On second thought, I bet that Me2 poured a couple 20 oz bottled drinking water in his fuel tank just for kicks.
I bet their is a huge conspiracy with 6.4 Ford owners, they pour random bottled waters in their tank.
This is a known issue and has been going on for a while now.
Good Grief.
Thanks!
