nayther wrote: I've had extremely good luck with Nitto. If you want a more agressive tire, like the T/A go Terra Grappler. If a more street tire is good (this is what I've run) go with the Dura Grappler. I got close to 50k out of my last two sets of Dura Grapplers on my 2005 2WD. They come in two classifications, make sure you get the 6 ply load range E.
I also have the Nitto Dura Grappler 285/75/16 "E"s. Love them. They seem to be wearing alot better than the BFG A/Ts (like those also), and a good bit quieter too.
BTW - I have air'd the Dura Grapplers down for Pismo trips, and they float across the sand just fine. Will buy them again. Hope this helps.
I have the Nitto Terra grapplers on mine 305/75/16 load E. They are wearing fine. And they were great on the sand at Pismo. Only thing about them is they have wide spacing in the footprint design. So when I get the trailer at storage they pick up all the small gravel and fling it around, when I hit the pavement again.
2013 Honda CRF250L
2006 F250
2006 W.W FSC2800
2006 Raptor 700R Mine
2002 CRF450R Son
2009 Polaris RZR 800 with 6" long travel suspension Wife
BF Goodrich All Terrain LT270/75/R18. Long lasting, nice all around tire. I am on my second set with absolutely no issues. I have 98,000 miles on my truck and had replaced the continentals at about 5,000 miles with my first set of BFG's.
06 Ford F-350 PSD CC FX4
05 Fleetwood Pioneer ASV 260FS
I'm a tire dealer and I have 06 f-350 4x4 see my signature, for the money the nitto terra grabbers is a very good tire, built by Toyo in the sane factory, pm me if you have any questions.
06 F350 4x4 Amarillo Pkg PSD,Juice W/Attitude, Air Bags
Cold Air Intake, Corsa Exhaust
2" Fabtech Kit W/Shocks
Superglide 5r Hitch W/ Super Rail Kit
K-Z 38bx2 Triple Slide With Mor/ryde Pin box
pcassidy111 wrote: Goodyear Wrangler Silent Armor has worked well for me on that truck. On 3rd set, get about 30K miles per set but I replace them when I get to 8/32 of an inch of tread remaining not when they hit the wear bars. Good rain and ice manners, works well in the snow and the desert.
I hope you mis-typed because 8/32 is only about 1/3 or less wear on them and you are throwing away good tires. Wear bars are between 1 and 2/32 and that's the time to replace. But it's your money and time to use as you wish.
Actually should have been 6/32 of an inch because in CA they are no longer legal as a snow tire, and they do sometimes check your tires at the chain control check points.
Dang, asking about tires is like asking which truck (ford/chevy/dodge) is better. Tons of opinions out there for sure. All valid and given honestly.
The Nitto's are made by Toyo.
My vote goes to the Toyo A/T's. I put 50K on my last set, and am now 10K miles into my 2nd set. In my opinion these are the best tires you can put on a full size truck that is towing a 5th wheel. Solid tire, great tread life, and when purchsed at the right place, great customer service as well.
DuneJunkie wrote: ... and when purchsed at the right place, great customer service as well.
good luck with your decision.
Now that is some sage advice there. I've been dealing with the same tire shop since my first car back in H.S. same owners that are over the top helpful, they're the ones that turned me on to the Nitto Terra Grapplers for my 1/2 ton. When I was ready to put tires on my Duramax I found the Dura Grapplers on the Nitto website and talked to my tire guy, he agreed they looked like a good choice and that's the way we went. Cannot say enough about dealing with a good tire shop, they want you back and will work with you. I've steered countless friends to Western Tire in Burbank, CA and everyone has thanked me after.
