RV.Net Open Roads Forum: Travel Trailers: awning screen room
 > awning screen room
jester13
home
Posted: 03/12/12 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
hello, i am wondering if i can buy a screen room that attaches to my travel trailer. i DO NOT have an existing awning, is there a company out there that makes an all in one awning/screen room to attach to a travel trailer??? i thought about just buying a screen tent and attaching it to my trailer, any suggestions?? thanks
skipnchar
Topeka or somewhere else
Posted: 03/12/12 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
In order to have an awning style screen room you pretty much need an awning installed. Keep in mind that awnings are generally not designed to withstand strong winds so if you live (camp) in an area that has sudden occuring strong winds (30 MPH and up) it's kind of a PITA to have to remove a screen room to raise the awning. Sometimes it's just as good an option to use a gazebo or stand alone screen room in place of an awning attached one. Your trailer so do what works best for you.
Good luck / Skip
boosTT
Milwaukee
Posted: 03/12/12 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
They are more hassle then its worth.
rgolding
Southern Illinois
Posted: 03/13/12 06:46am Link  |  Quote  |  Print  |  Notify Moderator
You can buy an independent, portable, gazeebo/canopy from Wally World or other big box stores for around a hundred bucks and get a screen that fits and goes around it for just a little more. Totally independent of your trailer and can be used for lots of things will camping and at home. No holes are drilled in your trailer. Two people can totally assemble or take down and store in its case in about 10 minutes.
* This post was edited 06/23/12 06:27pm by rgolding *
jester13
home
Posted: 03/13/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for all the help and suggestions, jason
boosTT
Milwaukee
Posted: 03/14/12 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I had one for my popup camper. It was needed because the small size of the popup. However, it took longer to setup the screen room then the rest of the popup. It's was also very difficult to pack the screen room up. Most campgrounds don't have a clean dry spot on the ground where you can fold such a large item. It also greatly limited camp site setup options, because you always had to enter the screen room from the one door. And the worst was always zipping and unzipping the door. If you don't unzip it all the way before you enter, expect your hair to get cought in the zipper.... ouch!
Even before I sold the popup we knew we would never purchase a screen room again.
DwnSth
SE Louisiana
Posted: 03/14/12 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Also had awning/screen-room/add-a-room on our pop-up. Somewhat difficult to set up....BUT, this thing saved several vacations when we had constant rain or out of control mosquitoes. At the time we had small children. Having the additional space to play and spend time was a lifesaver. Just ordered Vacation'r room to add to our new TT.
2012 Aerolite 212RBSL
2013 F150 Lariat EB S-Crew max tow HD payload
1996 Four Winns Horizon 190 (gotta have a boat down here)
old - 1995 Jayco 1007 pop-up (lost to a fallen branch)
mlts22
Austin, Texas
Posted: 03/14/12 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I would consider using a screen room with four caveats:
1: If my RV had two doors, so I wouldn't have to zip/unzip every time I went in and out. Plus, dealing with tracked in soil isn't fun either.
2: I was using it for a long term engagement, say the RV was parked at a renaissance faire for a quarter of the year. The setup process is tedious, and unless I was doing it to keep it operable for a relatively long time, I'd not want to spend the time in using it.
3: I was able to securely stake it down. Luckily this year at my usual camping spot, the winds were not as bad as they were last year, but it doesn't take much to rip an awning off a rig.
4: I could put down some type of floor, to help keep sand out.
JJBIRISH
Butler, PA, USA
Posted: 03/14/12 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
click
What you are asking about are called bag awnings and they do make screen rooms for them…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
robbie69
wauconda, il usa
Posted: 03/14/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
rgolding wrote:
You can buy an independent, portable, gazeebo/canopy from Wally World or other big box stores for around a hundred bucks and get a screen that fits and goes around it for just a little more. Totally independent of your trailer and can be used for lots of things will camping and at home. No holes are drilled in your trailer. Two pwoplw can totally assemble or take down and store in its case in about 10 minutes.
what i did and set it up myself. make sure you get one of the e-z up style. what's nice, if the wind picks up, i have just dropped it down on the legs and it has weathered several stormes that way. keep it in the pickup and have used on numerious day trips too.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
