RV.Net Open Roads Forum: Class C Motorhomes: Foam filled tires
 > Foam filled tires
tatest
Oklahoma Green Country
Posted: 03/13/12 08:28am Link  |  Print  |  Notify Moderator
GrumpyandGrandma wrote:
Wait long enough and you may be able to get the new plastic rims with rubber tread glued on. Don't laugh they're in the testing stage for cars. Understand they are already in use on some construction equipment.
How much construction equipment regularly runs at 70 to 85 mph?
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
GrumpyandGrandma
CIncinnati, OH
Posted: 03/13/12 08:41am Link  |  Print  |  Notify Moderator
As I said in previous post, they are on cars in SC (Michelin has a plant there) right now being tested on the expressway.
Grandma in front of her retirement home..
She lets Grumpy drive!!
mowermech
Billings, MT
Posted: 03/13/12 08:55am Link  |  Print  |  Notify Moderator
We used foam filled tires on some industrial equipment many years ago. This equipment ran, at best, at 15 MPH top speed. The ride was very rough, and the tires were (at that time) very difficult to balance. No, we didn't NEED to balance them, but it was an interesting exercise.
However, they completely eliminated the flat tire problem (it is amazing how many little pieces of welding rod a bunch of iron-workers can scatter around! Interestingly, the magnetism in an aluminum reduction plant tends to stand those little chunks of rod on end). Even with a chunk ripped out of the sidewall, the tire did not go flat!
So, expensive, heavy, difficult to balance, but they will not go flat.
Oh, yeah, when you order them, you can specify the "inflation pressure" you want!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
tatest
Posted: 03/13/12 09:00am Link  |  Print  |  Notify Moderator
Michelin is running scrapers, graders, dozers and cranes down the highway at 70-85 mph? Videos please?
GrumpyandGrandma
CIncinnati, OH
Posted: 03/13/12 09:51am Link  |  Print  |  Notify Moderator
THEY ARE TESTING THEM ON EMPLOYEES CARS!!!
new2me350rv
Posted: 03/13/12 10:36am Link  |  Print  |  Notify Moderator
Thank you ladies and gentlemen (I love this forum!).
Handbasket
Asheville, NC
Posted: 03/13/12 10:51am Link  |  Print  |  Notify Moderator
I'm thinking that there may be two things being discussed here. Foam filled tires, and flexible plastic spoked wheels that just have a thin solid 'tire'. I think Michelin is testing the latter.
Jim, "I lent a friend of mine $10,000 for plastic surgery. Now I don't know what he looks like!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
oldtrucker63
Harlan Kentucky
Posted: 03/13/12 02:21pm Link  |  Print  |  Notify Moderator
Ivylog wrote:
Yes, it's $250 to add the foam to your tire. Harder to cut it off the rim than you might think as it's hard to get at the steel in the beads. Michelin has been experminting with the airless tires for a long time and I've yet to see them in actual use???
They're are on cars in SC(testing) as we speak. They had to get a special permit and are only allowed in SC.
Search it on U-Tube, There cool and you can buy them right now.
Without Trucks,....America Stop's
recycler
michigan
Posted: 03/13/12 04:06pm Link  |  Print  |  Notify Moderator
one thing not mentioned is foam filled tires are VERY heavy off road forklifts use it for two reasons punctures and WEIGHT to counter balance long booms
1968 franklin 11fk
back to my 93 cummins
hohenwald48
Hohenwald, TN
Posted: 03/13/12 09:43pm Link  |  Print  |  Notify Moderator
I have one on my wheelbarrow. Works great.
2008 Fleetwood Jamboree 25G
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
 > Foam filled tires
