RV.Net Open Roads Forum: Travel Trailers: Travel trailer parking pad
 > Travel trailer parking pad
Herd Fan
West Virginia
Posted: 03/13/12 05:27pm Link  |  Print  |  Notify Moderator
Hello...just a quick question- We're having a rock pad put in at the house. What size(s) rock, depth, etc...would you suggest from your experience? Thanks in advance for your help!
2012 Dutchmen Classic 276RBS
2007 Dodge 2500 5.9L CTD, 4x4, quad cab
korbe
Northern California
Posted: 03/13/12 05:39pm Link  |  Print  |  Notify Moderator
I would put in about 4 to 6 inches. I would not use washed rock. I would use a graded 3/4 inch minus and compact it with water added.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
jasult
Central NJ
Posted: 03/13/12 05:54pm Link  |  Print  |  Notify Moderator
look here another thread same subject
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
skipnchar
Topeka or somewhere else
Posted: 03/13/12 07:03pm Link  |  Print  |  Notify Moderator
Enough to keep the wheels from sinking into mud is all that's needed. As much MORE than that as you want to put down.
rgolding
Southern Illinois
Posted: 03/14/12 05:10am Link  |  Print  |  Notify Moderator
If you are putting 6 inches or more to level the area, I would start with 2 to 3 inch limestone for a solid base and then top with 2 to 3 inches of 3/4 minus for a smooth surface. In lots of areas, if you just put the 3/4 inch minus down the mud will just eventually "ooze" up through it.
dpark
Central PA
Posted: 03/14/12 08:30am Link  |  Print  |  Notify Moderator
Are they digging out the sod/top soil first (recommended)? If so, you could put down 2-A stone for all, but I would put #3 limestone or sandstone down and then use 2-A on the top to compact down and firm it up.
2011 Toyota Tundra, Crew Max, TRD, SR5
2011 Open Range Roamer RT303 BHS
Prodigy Controller
Honda EU2000is
mlts22
Austin, Texas
Posted: 03/14/12 09:45am Link  |  Print  |  Notify Moderator
It can't hurt to use the plastic sheeting, (forgot name, but it is specially designed for this task) to keep weeds from popping up through the stone.
Herd Fan
West Virginia
Posted: 03/14/12 10:26am Link  |  Print  |  Notify Moderator
Thanks for the replies. Yes, there will be some digging/leveling...so I planned on at least 6" depth. As for a weed barrier, I don't want a weed problem but I also don't want a drainage issue. So, what is the ideal material and where can I get it? I assume that those that used fabric bought something heavier than landscaping fabric? For those that suggested plastic, wouldn't that eliminate draining?
FYI...I've been reading/talking to people and some say you will still get weeds even with a weed barrier under the rock. (So I guess the "anti-fabric" crowd just sprays their gravel for weeds a couple times a year). Whether I use a fabric will depend on the price, I guess.
* This post was edited 03/14/12 10:57am by Herd Fan *
rrev
Beatrice, NE
Posted: 03/14/12 11:24am Link  |  Print  |  Notify Moderator
If you want to not have weeds, pay a lawncare service to come and sterilize the area every spring. Weeds will still grow in rock because all it takes is to have the seeds blow into the cracks between the rocks.
md2lgyk
WV
Posted: 03/14/12 11:36am Link  |  Print  |  Notify Moderator
I'd add some stone dust as well, and plate compact the whole thing.
"The great object is, that every man be armed. Everyone who is able may have a gun." - Patrick Henry
