RV.Net Open Roads Forum: Smaller than SQ1? Stab! Stab! Stab!
 > Smaller than SQ1? Stab! Stab! Stab!
backbencher
Posted: 03/13/12 09:42pm Link  |  Print  |  Notify Moderator
/Rant
So, the rear leftside weld on the back quarter panel of the '01 Dodge R/T 190 Versatile has popped open, & Stahmann's is gonna weld it for me. IOT save hours of billable labor, we agreed that I'd pull the wall out & reinstall, since I have more time than money @ the moment.
SQ 1 bit? Check. SQ 2 bit? Check. I am now ready to do any maintenance on a Road Trek. Except - the screws on the curtain tracks are SMALLER than a SQ 1. Ok, they're not too tight, so I can finagle them out w/ a flat blade.
That done, I'm removing the bottom shelf panel over the jack, so I can remove the side panel. ALL the SQ 2 screws are out, so why won't it move? Is it glued? No, the Canadian Prime Minister is STAPLED AND NAILED IN! Worthless PRESIDENT of a French Republic!!
Rant/
Every SINGLE screw I take out of this thing from now on will be replaced by a proper Phillips screw. Every single last trusted dependable NATO ally of them.
Gig 'em,
backbencher
My Roadtrek
Tucson, AZ.
Posted: 03/14/12 01:20am Link  |  Print  |  Notify Moderator
I believe the screws in the track are rivets, and need to be drilled out.
I liked the square head screws, a lot harder to strip than a Philips Head.
kaydeejay
SE Michigan, USA
Posted: 03/14/12 03:05am Link  |  Print  |  Notify Moderator
Bit late, but SQ-0 bits are available. I have one.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Atlee
Mechanicsville, VA
Posted: 03/14/12 03:11am Link  |  Print  |  Notify Moderator
Agree on the square head screws, much better and much preferred. Granted the sampling universe is much smaller on the square head screws, but if I look at a Philips head screw, it strips.
Erroll, Mary, Duffy the Badger Dog plus "Ollie"
2009 HiLo Towlite 2209T
2005 F150 Supercab 4x4, w/ 5.4L
1996 RoadTrek 210 Popular, on 1995 Chevy Chassis
Handbasket
Asheville, NC
Posted: 03/14/12 06:38am Link  |  Print  |  Notify Moderator
And usually a square drive screw will stay on the bit for insertion into one of those hard-to-reach holes, without needing a magnetic bit. I like 'em, myself. Provan uses them on the Tiger.
IIRC, I found a size zero bit at Lowe's or Home Depot some years back when I relocated my '02 C190P's rear door curtains.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
PCarnathan
Menifee, CA
Posted: 03/14/12 04:56pm Link  |  Print  |  Notify Moderator
As a finish carpenter I'm a firm believer in the value of square-drive screws. They won't cam out like a phillips - You can put a lot more torque on a square drive screw. They're the bomb. Conversely, there should be a law against slotted screws!
Pat in Menifee, CA
www.patcarnathan.com
OldRadios
Upstate New York
Posted: 03/14/12 05:26pm Link  |  Print  |  Notify Moderator
Just an FYI, my 1985 B is fitted throughout with square drive screws. Its easy to find the bits to fit them.
backbencher
Posted: 03/14/12 10:27pm Link  |  Print  |  Notify Moderator
Nope. The little NATO troops are SQ #0, as the good chap pointed out. Not that Home Depot or Northern Tool have SQ #0 bits.
Gig 'em,
backbencher
My Roadtrek
Tucson, AZ.
Posted: 03/14/12 10:40pm Link  |  Print  |  Notify Moderator
Amazon has them.
http://www.amazon.com/Wera-Series-Sheet-........r3_2?ie=UTF8&qid=1331786406&sr=8-2-fkmr3
http://www.amazon.com/Bondhus-11640-Squa........ref=sr_1_1?ie=UTF8&qid=1331786406&sr=8-1
* This post was edited 03/14/12 10:46pm by My Roadtrek *
