RVcrazy
Puyallup, WA, USA
New trucks are getting so tall, we wonder what issues you have had with bed clearance with your fifth wheel. How did you resolve the issue without having a high nose? Thanks.
Mitchellg
St.Louis
I've got a 2011 2500hd with z71 and z81 suspension(heavy tow pkg). it still high, a good 3-4 inch higher than my father in law's 2005 2500.
My k-z fifth sits nose high enough, that we can't sleep in it while hooked up. The only thing we had to do was adjust the suspension. No extra tire wear so far.
Also, since the bed rails are so high we had to try out 3 different pin boxes. With the standard box turning past 45 degrees would cause the box to hit the bed.
REWahoo
Texas Hill Country
I did an axle flip on the trailer to raise it a few inches - problem solved.
2011 Silverado 2500HD LTZ Duramax 4x4
2007 Jayco Eagle 291RLTS
agesilaus
North Florida
That's something I've been thinking about since I have a F350 4WD on order. I stopped by the Ford lot and measured the rail heights and they are 59 inches. I think someone said that the Dodge trucks are 61 inches. I talked to a local trailer shop and they'll flip the axles on a 5ver for less than $300 so we may end up doing that.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
car2900
Mount Juliet, Tennessee
Same problem here. My 2011 Chevy 2500 HD is a good two inches higher than my 2009 Chevy 2500. I had to take my Access tonneau cover off as it has a rail system that is a little over an inch above the bed rail of the truck. I then lowered my hitch head about 1 1/2 inch. I have about 6 1/2" clearance from bed rails to bottom of front of 5er. My 5er., still runs about an inch or two nose high. Temperature of back tires while towing don't seem to be much different from front axle tires thus I don't "think" I have too much weight on the back tires. I will get it weighed as some point. Back of pin box still comes very close to the truck bed rails. I now have to carry a small aluminum ladder just to get up in the back of the truck bed. Just wish the new trucks were not so high in back.
The distance from ground to top of bed rail is about 57" on my Silverado 2500 HD 6.6 D/A 4x4.
2012 Palomino Sabre 31 RETS-6 (6,000# axles)
2011 Chevy Silverado 2500 HD Duramax/Allison 6.6, 4x4
B&W Patriot 16K
jalichty
Lander, Wyoming 82520
Bought a new Dodge Ram 2500HD last fall and purchased a new Jayco Eagle SuperLite 26.5 RLS in January. Finally picked it up from the dealer last Monday and got a hitch put on it. I was afraid of the height of the truck, but when hooking the new FW up, it appears to only be about 1" or so high in the front. The guy helping me hook up said they usually like to see a vertical fist between the bed the the bottom of the FW overhang and we were only short a bit. He said it should be ok. Hopefully it stays this way. FW pulled great on its maiden voyage, just short of 500 miles, we'll see what happens when we get it fully loaded, DW if working on it every day to make sure we leave nothing out when we leave after April 15.
John A. Lichty
Frank&Renae
Madison, SD
Before flipping the axels I would check with the manufacturer of the RV. There was another thread about frame cracks and some of the cracked frames were blamed on flipping the axels.
Just my $0.02 worth YMMV
Frank now without Renae
KZ Montego Bay 37CKM
2007 Dodge 3500HD DDW
Three cats -- Sunkist, Topaz, & Amber
One dog -- Rascal
Started Full Timing since March 26, 2008
bailer6334
Prescott, AZ
Guess I'm lucky with my combo. No mods or adjustments necessary on either, when I switched from my 07 Ram to my 2011 Chevy 4X4.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
Shepherd
St. Clairsville, Ohio
My KZ axles are already under the spring pack. I had a leveling kit installed on my truck which should help at the tailgate.
2012 Ram 3500 HO GCWR 30K
2012 Durango 2500
AZ T&T
Mesa, AZ
I had to have a 4" lift installed on my FW. Now we are towing level and have 9 inches of clearance.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
