RV.Net Open Roads Forum: Fifth-Wheels: Trouble with older 5th & new truck height?
 > Trouble with older 5th & new truck height?
elkhorn98
Santa Rosa, California
Posted: 03/14/12 08:10am Link  |  Print  |  Notify Moderator
Axle flip and 4" sub frame added under fifth wheel and I don't have enough clearance yet but it works.
Elkhorn98
2010 GMC Sierra 2500HD 4x4 Duramax/Allison w/45 gal Transfer Flow Tank
RBW X16 Slider, Yamaha EF 2400iS
2007 Springdale 245 5th Wheel - E-Z Flex HD Suspension & Mobile Outfitters Shock Kit Upgrades
with Firestone Transforce Ht Lt 2357515 C tires
Here'n'There
Posted: 03/14/12 09:55am Link  |  Print  |  Notify Moderator
Hummm... I must have missed the OP's point!
Here's what I'm thinking.... Isn't your pin box adjustable? Mine is a Mohr-Ryde and the pin can be adjusted to 3 different heights. Wouldn't that solve the problem?
Continuing to make myself a fool... if your pin box is NOT adjustable, I think I would opt for a new pin box before flipping axles!
Sorry if I am way off base...
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
gmcsmoke
Butler
Posted: 03/14/12 10:04am Link  |  Print  |  Notify Moderator
flip axles or install lift blocks on fw
AZ T&T
Mesa, AZ
Posted: 03/14/12 10:13am Link  |  Print  |  Notify Moderator
In my situation, if I would have just adjusted the pin box I would have been either very nose high or wouldn't have had any clearance between the FW and the truck bed. That's why I fully extended the pin box to get the clearance and then added the 4" trailer lift to level the FW.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Snowman9000
IL
Posted: 03/14/12 06:47pm Link  |  Print  |  Notify Moderator
And we will soon need a staircase to get into our 5ers.
2004 Chevy Duramax 2500HD 2WD Crew Cab. B&W Patriot hitch.
2004 Crossroads Cruiser 28RL 5er.
2005 R-Vision Trail Lite B+ 213 6.0 Chevy 3500
HarleyEnough
PA
Posted: 03/14/12 07:12pm Link  |  Print  |  Notify Moderator
You can replace your 3 step RV steps with a 4 step model. Some of the new fivers are coming with them. Or you can build a little box to set at the bottom if raising the fiver has pulled the bottom step too far from the ground.
2011 Dodge Ram Laramie 3500 Crew Cab Long Bed SRW
2006 KZ Sportster 41GKx2 Toy Hauler
KZOwnersForum.com
mobilcastle
OH
Posted: 03/15/12 05:24am Link  |  Print  |  Notify Moderator
Change to a standard pin box-it usually works. Gets the pin box inside the rails. In looking at some new 5vers it appears the pin boxes and mounting wings on some models are being cut on an angle to help with higher bed rails.
2010 Heartland 3670RL Mor/Ryde PB,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
cKarlGo
Alexandria, VA
Posted: 03/15/12 06:45am Link  |  Print  |  Notify Moderator
RVcrazy wrote:
New trucks are getting so tall, we wonder what issues you have had with bed clearance with your fifth wheel. How did you resolve the issue without having a high nose? Thanks.
When I went from my F250 to my Chevy 3500, I had to drop the pin on my 5er. Even though the truck was lower (F250 had the offroad package) the Chevy had a deeper bed.
Many factors play into this beyond the height of your truck.
k.
2012 Montana 3402
2011 Chevy 3500
2007 Black Lab/Pitt Bull mix named Harley
nisham
home
Posted: 03/15/12 04:07pm Link  |  Print  |  Notify Moderator
I had same problem. I flipped axles and still hit my trailer when going down with front of truck and trailer coming up a hill an inverted V situation. I had a body shop cut from the center pin pockets on bed of truck down and the toward the top of the taillight and cut the tailgate down also. It was done to a 2004 Dodge 2500 4x4. The cost was 1500 dollars but well worth it to me. I no longer have to worry about going over a bump or rise. I do do a lot of offroad camping with a 30 WBLE Cardinal.
greende
Syracuse,NY
Posted: 03/15/12 04:20pm Link  |  Print  |  Notify Moderator
It seems as though the 5er manufacturers are getting smarter. My new 2012 Cougar came flipped from the factory and it rides pretty close to normal. It also has mor ryde equalizers from the factory and the pinbox is chamfered at the back to keep from hitting the side of the box. I may need to do a little tweaking but it was pretty good right out of the box when hooked to the 3500HD DRW.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
