RV.Net Open Roads Forum: Tow Vehicles: new truck
Search only in Tow Vehicles
 > new truck
Mile High
Denver, CO
Posted: 03/14/12 08:52am Link  |  Print  |  Notify Moderator
My 2006 6.0 has been perfect - no more or no less service calls than my 7.3 before that. Love the TorgueShift transmission in the 2006. I think most of the 6.0 issues were in the 2003/2004 range.
With that, I personally wouldn't give that kind of money for any truck with 100,000 miles, but you do make it sound like mine must be worth more than I paid for it new!
Last - your pin weight on that rig is going to be closer to 2,500 lbs loaded. 3,000 lbs would be a little extreme for that gross weight.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
PA12DRVR
Anchorage, AK
Posted: 03/14/12 08:56am Link  |  Print  |  Notify Moderator
I had two 2006 F350's with the 6.0 (first one was stolen) and had no problem with either one towing a 15,500# fifth wheel. For something of the size you're looking at, I'd get a dually.
CRL
Displaced Alaskan NO MORE!
My RV is a 1946 PA-12
Fire5er
Port Orchard, WA
Posted: 03/14/12 09:05am Link  |  Print  |  Notify Moderator
I had a new 2006 F350 SRW 6.0 PSD and towed a 13800 lbs (weighed) 5er with it for 5 years and it did a great job, then traded it in for a 2011 F350 DRW 6.7PSD and tow the same 5er. What a diferance the DRW made in stability.
As for the reason I traded the 6.0 in...all the issues the Ford 6.0 PSD had and the fact that I started to lose coolant from my degass bottle which is a sign of the EGR going bad. If the 6.0 PSD you are looking has an EGR delete kit then go for it, but if not I would look at somthing else. The 7.3 PSD is a great engine, and so far the 6.7 is an outsatnding powerfull engine.
2011 F350 CC, 6.7, LB, DRW.
Hijacker (24-UMS-21) 21k Underbox Hitch.
2007 Keystone Montana 3400RL (38'9")
PressurePro Tire Pressure Monitoring System.
brirene
midwest
Posted: 03/14/12 09:39am Link  |  Print  |  Notify Moderator
cefloyd 1961 wrote:
1 more question would a 2008 f250 with a 6.4 POWERSTROKE DIESEL FX4 CREW CAB with 132000 miles pull my camper?it cost about the same as the others
Yes, but pin weight might be a consideration on the 250.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
cefloyd 1961
kentucky
Posted: 03/14/12 09:55am Link  |  Print  |  Notify Moderator
I am trading in my hd2500 6.0 gas hog and it is paid for and I had to have a used motor put in it this week becouse i blew it up pulling my 5er up a long big mountin lol so concerding they are going to give me 10500 trade in on mine i will only have to put about 11 thousand with it pmts of less that 210 a month
2006 f350 superduty 6.0.. 2012 sandpiper 345RET loaded
45Ricochet
North Idaho
Posted: 03/14/12 11:14am Link  |  Print  |  Notify Moderator
downtheroad wrote:
cefloyd 1961 wrote:
what do you all think?
I would be careful and leery of the 05/06 PSD 6.0. Just too many well documented issues.
(many have had good service from theirs, many many have not without expensive protection upgrades.)
Google "Ford 6.0 psd problems" and start reading.
Good luck with your choice.
X2
Do your homework and be prepared to spend a few more bucks getting it bullet proofed. They can be made reliable with a few mods.
Good Luck
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
pressure_welder
brandon
Posted: 03/14/12 11:30am Link  |  Print  |  Notify Moderator
id stay far... far away from a 6.0L i may be bias but i have 350,000km combined trouble free KM on my duramax's. When i mean trouble free, im talking nothing other than changing oils/tires/filters. I have quite a few friends that "ran" powerstrokes and now 4 are switching to the new LML duramax, and two are moving to cummins. One purchased a brand new ford and totally blew the motor at 30,000km pulling his 30' fifth wheel. Ford didnt even stand behind their truck and refused to warrenty the issue until he took them to court!
2012 Duramax Denali Dually
2003 Triple E topaz 29' luxury touring edition.
1850 crestliner sportfish w/ 150 optimax
57 Panhead
Central Valley Calif.
Posted: 03/14/12 11:46am Link  |  Print  |  Notify Moderator
I think you can get a truck in the range you are looking at with a lot less miles and about the same price. Have you checked Carmax? They have a good selection and seem to be priced very good. I bought my 2007 F250 from them for $25,900 in October of 2010 with only 11,000 miles on it and a good OASIS report and clean CarFax. Still under factory power train warranty and runs like a champ.
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
joendeb92
Central Ohio
Posted: 03/14/12 01:39pm Link  |  Print  |  Notify Moderator
For the same money you maybe able to find a medium duty. My 7.3 w/4R100 tranny went out at 100,000 miles and my 2007 6.0 new headgaskets and Turbo at 19,000 miles. both replaced with Heavy duty toter
bpounds
Whittier CA
Posted: 03/14/12 01:50pm Link  |  Print  |  Notify Moderator
As a 6.0 owner, I can assure you that you will need to spend some money on the truck, if it hasn't been done already. And you can get screwed badly on those repairs if you don't educate yourself and find the right shops. The right shop will NOT include any Ford dealership. The fact is that diesel ownership, of any brand, is not cheap. If you don't have the pocket depth to spend several thousand at any given time, stay away from diesel and just muddle along with a gasser. If you are budget minded, you cannot afford a diesel. Of course there are exceptions and some run and run and never break. And it doesn't really matter what brand. You can be lucky with any of them. Like most thing in life, and especially owning a diesel, being dumb is very expensive.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
 > new truck
