RV.Net Open Roads Forum: Tow Vehicles: Ram front driveshaft service
Search only in Tow Vehicles
 > Ram front driveshaft service
ib516
Way up north eh
Posted: 03/14/12 09:29am Link  |  Print  |  Notify Moderator
You know that infamous little grease fitting we Dodge/Ram owners are always trying to lube on the front drive shaft? Well, it's such a pain, I am planning on removing the driveshaft to accomplish the task, and ensure it is done right. Sounds like a good plan for a Saturday afternoon. Anyway, if you're thinking the same thing, here is an excellent write up I found, complete with good quality photos, on how to R+R the front driveshaft and get everything lubed up as it should be.
ENJOY!
LINK
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
netomh
Far North Dallas
Posted: 03/14/12 09:46am Link  |  Print  |  Notify Moderator
I thought that fitting was mythical...I've certainly never found it on my truck! [emoticon]
I jest...mine's 2WD...[emoticon]
2010 Ram 2500HD Crew ST, 6.7L, 68RFE, bone stock.
2010 Keystone Sprinter 311BHS
Jack in Alaska
Anchorage & Ninilchik, Alaska
Posted: 03/14/12 09:47am Link  |  Print  |  Notify Moderator
I did that very thing to grease my front drive shaft. Imagine my surprise when we could not find any zerk anywhere on the shaft, u-jts. etc. Put it back and all is well at 100k miles.
Jack
2004.5 Dodge 3500 CTD 325/610 Laramie DRW 4x4 6spd 3.73
Smarty Jr; HiJacker Hitch;TrailAir pinbox;Prodigy;PacBrake;
Access cover;DeeZee;LightForce road lites; Westach EGT/Boost
2012 Jayco Jay Flite 40FER Bungalow TT
Yamaha 3000 iSEB gen.
Capt Skup
Southern Maryland/Nantucket
Posted: 03/14/12 09:50am Link  |  Print  |  Notify Moderator
If you have a diesel, I would caution on using those stamped steel ramps. I crushed one with my '04 PSD. Now I use serious jackstands. Also there is an adapter for grease guns that use what is called a needle(from my aircraft maintenance days) that you can fit into that small grease recepticle without disassemlby. But greasing that spline is a very good idea. You can buy the proper metal clamping straps and the tool needed at good auto supply shops.
BTW, be careful greasing your "female" splines. [emoticon] Might be illegal in some states
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
F-450 Lariat 4x4
Honda Odyssey EX-L
SunlineF281SR
SeaRay 240 Sundeck
http://community.webshots.com/user/CaptSkup?vhost=community
45Ricochet
North Idaho
Posted: 03/14/12 10:54am Link  |  Print  |  Notify Moderator
I gave up. Even if I had the needle I still can't see where the tiny little hole is with my reading glasses on.
On edit nice link IB. At least I know there is indeed a hole in there somewhere. [emoticon]
* This post was edited 03/14/12 11:03am by an administrator/moderator *
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
BenK
SF BayArea
Posted: 03/14/12 11:01am Link  |  Print  |  Notify Moderator
Had one of these on my 1973 K5 Blazer and remembered that there were several
threads here on that type of grease fitting.
I've found many covered with old grease, road grim, etc
Found one thread:
The Phantom Grease Fitting
Suggest you look for one of these for your grease gun...mine has a
rubber tip, but either that or the one pictured should do
* This post was edited 04/24/12 05:50pm by BenK *
-Ben Picture of my rig
ib516
Way up north eh
Posted: 03/14/12 11:07am Link  |  Print  |  Notify Moderator
I have a 4" needle, exactly like the one BenK posted a picture of, I even "custom" bent it to get in there. Still once you let one tiny bit of grease slip by, it covers the opening, and you're back to poking a screwdriver/rag in there to try to clean it off so you can see where you're trying to grease, and it happens again. I walk away a bit frustrated never knowing if I got grease in there or not.
At least this way, I will know it's done right.
ib516
Way up north eh
Posted: 03/14/12 11:08am Link  |  Print  |  Notify Moderator
It's there. It's as hard to find as hen's teeth, but it's there.
ib516
Way up north eh
Posted: 03/14/12 11:09am Link  |  Print  |  Notify Moderator
Yes, good point. I have those ramps, but only the minivan climbs up on them. I'm sure Megacasper would crush them.
coolbreeze01
Redding, Ca
Posted: 03/14/12 11:13am Link  |  Print  |  Notify Moderator
A guy posted about ruining some of his bolts, not knowing about the Loc-Tite. Takes heat to release the red, I don't know about blue. Have fun.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
