far733
Michigan
I am looking for a truck to pull my travel trailer that weighs 6000lbs loaded.
I am considering the following vehicles:
- 2008 Ford F150 Super Crewcab 4x4 with the 5.4L V8 and the 3.73 rear axle with 18 inch tires.
- 2008 Dodge Ram 1500 Quad Cab 4x4 with the 5.7L V8 Hemi and the 3.92 rear axle with 20 inch tires.
I am wondering what your experiences are with either of these trucks. I know that the F150 is rated to pull 8700lbs while the Ram is rated to pull 7500 (or 8500 lbs if I put 17 inch tires on it). Thanks for your help!
fla-gypsy
North Florida
Both will handle that weight safely and effectively
BradinOhio
Akron, Ohio
I have no issue and am happy pulling our TT (5600 # loaded) with my 2007 F-150 4x4 SuperCrew. I have the 5.4L V8, 3.73 rear, with 17 inch tires, and towing package. Might want to also check the available payload capacity between the two trucks you are looking at. My F150 is listed at 1,625 lbs per the yellow sticker. Good luck!
Brad ('68), Sandy ('71), Amber (shephard), Niko (shiba inu)
'12 F-150 XLT SuperCrew 4x4 Ecoboost with MaxTow
'12 Flagstaff V-Lite 30WRKSS
'10 Keystone Passport UL 245RB (prior - retired 6/2012)
'07 Rockwood Roo 21SS (prior)
skipnchar
Topeka or somewhere else
I suspect also that both will make a fine tow vehicle for your trailer. for what it's worth, I've towed my 6,000 lb. Coachmen (40,000 miles) and my 8,000 lb. Rockwood (50,000 towing miles) with my 04 model F 150 and it never required a repair of any type. I suspect the Dodge may have a little more power but hard to beet the Triton for reliability.
Good luck / Skip
APT
SE Michigan
Ram engine and trans, F-150 crew cab size. Ram's quad cab is really and extended cab with forward hinged doors. If you have people to put in the back seat, F-150 all the way. If you can swing it, a 2009+ F-150 Supercrew is significantly better in terms of an even larger crew cab and a 6-spd trans with better ratios than the Ram.
2012 VW Passat TDI
luve2camp
New York
They will both make a great TV. For me I would take the Ford..the 5.4L is a very proven motor
2011 Dodge Durango
2010 Jayco JayFlight 19BH
1970 Glastron 156 Sportster Tri-Hull
Countless motorized "toys" for us and the boys
Me, The Wife, 2 Boys and Ruger and Gunner the hairy drooling Boxer children
God Bless America
Stand Tall Freedom Doesnt Come Free
far733
Michigan
The wife likes the Dodge the best!
Can someone explain why the Dodge is rated to pull less than the Ford if it has more horsepower and torque?
eric james
Sioux Falls, SD
Get the one the Mrs. likes.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
ib516
Up here!
The RAM will be a slightly better puller IMO.
The Hemi is 345hp, the 5.4L is 310 hp.
The RAM has a 5 speed auto vs the Ford's 4 speed.
The performance difference won't be huge though, and both would do a fine job I'm sure.
This is for 2009s, but here is a comparison test close to the model years you're looking at. http://www.insideline.com/dodge/ram-pick........kup-truck-comparison-test-and-video.html
edited 03/14/12 10:48am by ib516 *
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
TomG2
Central Illinois
Like someone else mentioned, the Hemi has more power. I found the three 5.4 Ford V-8's I owned, to be lacking in that department.
