RV.Net Open Roads Forum: Tow Vehicles: Four wheel drive or two wheel drive?
Search only in Tow Vehicles
 > Four wheel drive or two wheel drive?
Page of 9
Sport45
Not far enough from Houston, TX
Posted: 03/15/12 09:21pm Link  |  Print  |  Notify Moderator
Engineer9860 wrote:
Someplace that you need 4x4 to get the clubs to the golf course, and milk, and bread home.
A place with clubs, golf course, and a market but no paved roads. Interesting.
'00 F250, CC SWB 4x2, V-10 3.73LS.
'83 F100 SWB 4x2, 302 AOD 3.55.
'05 GMC Envoy 4x2 4.2 3.73L.
Engineer9860
Eagle Scout dad
Posted: 03/15/12 09:26pm Link  |  Print  |  Notify Moderator
I didn't say you would use 4x4, I said you need 4x4.
In Memoriam: Liberty Belle
MitchF150
Washington, the State
Posted: 03/15/12 09:47pm Link  |  Print  |  Notify Moderator
Wow.. It's taken 5 pages of posts and only about 3-4 actual posts about how to adjust for a 5th wheel with a 4x4 truck...
The OP didn't ask about the need or the want of a 4x4 truck.. He asked that he's looking for a 4x2, but is getting a 'good deal' on a 4x4 and wanted to know how that would affect towing his existing 5th wheel....
4x2 compared to 4x4 ranks right up there with 'what sway control', 'what's the max trailer I can tow', 'what size truck do I need', 'can I drive with my fridge running on gas' posts!
I have my reasons for wanting a 4x4 over a 4x2 for towing a trailer, but that's not the question that was asked, was it??
Anyway, raising the 5th wheel axles is about the only thing you can do if it's too low and will ride 'nose high' and less clearance on the bed rails with the taller 4x4...
Good luck to the OP with his decision..
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
45Ricochet
North Idaho
Posted: 03/16/12 12:17pm Link  |  Print  |  Notify Moderator
Engineer9860 wrote:
rick83864 wrote:
Engineer9860 wrote:
Consider this:
Where I live you can't give a 4x2 away. Most of the time dealers send them off to auction. There just isn't a market used 4x2 trucks around here.
I never could figure out where your from
I don't have many neighbors but it sure sounds like your one of them
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
TomG2
Central Illinois
Posted: 03/16/12 12:53pm Link  |  Print  |  Notify Moderator
"Anyway, raising the 5th wheel axles is about the only thing you can do if it's too low and will ride 'nose high' and less clearance on the bed rails with the taller 4x4..."
Wouldn't you actually "lower" the axles relative to the rest of the trailer to raise it? Kind of a "Don't raise bridge, lower the river" situation. Lots of comments on here but not a lot of great advice.
Dixie Flyer
Piedmont, SC 29673
Posted: 03/16/12 02:57pm Link  |  Print  |  Notify Moderator
I brought th etruck home and with careful measurements we have determined it will be a perfect fit. The distance from the bed rails and the camper will be 6 inches and the camper will be level.
2012 Ford King Ranch F-350 Crew Cab Diesel
2011 Montana 3580RL
Wife Sue
Pets: Rainbow Bridge: Old Fella, Levi, Charlie. Others Suzie, Peaches, Hobo, Mama, Izzie
Old Fella Burke County Animal Rescue
wilber1
Abbotsford B.C. Canada
Posted: 03/16/12 03:04pm Link  |  Print  |  Notify Moderator
Depends on your need for 4WD. While it can be handy, there are disadvantages to 4wd. I have had both and for normal towing, the 2wd was more user friendly. I didn't need a step stool to access stuff the bed. Easier to get in and out of. A bit better mileage and lower mtc costs. A 4wd is just more complex. A 2wd drive will also have a higher payload capacity because it is a lighter truck without the extra weight of the front differential, drive shafts and transfer case. I had to put the pin box on my 5er to its highest setting to get the trailer level with the 4X4. An axle swap can solve level problems but raising the 5er can't help its stability and a higher profile will mean more drag.
On the other hand, if you think you will be using the truck in places where you will need the extra traction, you should get 4wd.
"Never trust a man who has not a single redeeming vice" WSC
8iron
Canada
Posted: 03/16/12 03:17pm Link  |  Print  |  Notify Moderator
WOW! very nice looking setup! Glad it worked out for you, enjoy.
2011 F250 Lariat FX4
2011 Sunset Trail Reserve 29ss
Engineer9860
Eagle Scout dad
Posted: 03/16/12 04:31pm Link  |  Print  |  Notify Moderator
6" of bed/fiver clearance should be fine if you don't have much boon docking in your future.
You don't want it too high. The higher it gets the worse your aerodynamics will be.
(I wonder if my latest reply to the OP is good enough to satisfy the forum Nazis?)
MitchF150
Posted: 03/16/12 05:52pm Link  |  Print  |  Notify Moderator
That does sound better!
Mitch
Page of 9
