RV.Net Open Roads Forum: Class A Motorhomes: TST Tire Pressure problems
 > TST Tire Pressure problems
racerchaser
Southwest Missouri
Posted: 03/15/12 11:03am Link  |  Print  |  Notify Moderator
After noting that the TST tire pressure system has had good reviews on this forum I ordered a set. Today was to be "learn about the system and set up the sensors" day. Did not go well. Upon trying to fit the first sensor to the right front wheel valve I find there is not enough room in the wheel opening for the sensor to fit. These are Accuride wheels with rather narrow triangular openings. Same situation on the outside duals. The sensors will fit on the inside duals. The most obvious fix would be to use short valve extenders. However, I am somewhat concerned about the front wheel sensors extending beyond the wheel surface and possibly getting damaged from road debris. Also, the outside dual installation would have to be done by reaching between the duals and I haven't gotten far enough to even see if that is feasable. Has anyone else run into this problem and, if so, what was your fix. Yes, I know there are other systems out there that might work but let's stick to this problem first.
Fox
ronfisherman
SE Michigan
Posted: 03/15/12 11:38am Link  |  Print  |  Notify Moderator
Short extensions or valve stems that stick outside of wheel. Another option on rear wheels is Crossfires.
Kodiak Chassis Class C Forum
FIRE UP
Ramona, CA. USA
Posted: 03/15/12 11:42am Link  |  Print  |  Notify Moderator
racerchaser,
Well Sir, this is incredibly interesting. The DW and I have been discussing the purchase of a tire pressure monitoring system. In watching the posts and threads on this forum, I've come to the conclusion that there is basically two "senior" systems or, brands I should say to choose from.
One is, Pressure Pro and the other is TST. After some zig-zagging back and forth on their respective web sites, I felt the TST was the way to go. I came dangerously close to pulling the trigger way more than once on ordering a system up. I just didn't. Not sure why, just didn't. It's not the price, that's not the issue, I just didn't.
But, now, in reading your post, I'm kind of glad I hesitated. I'm including a picture of my wheels and am reasonably sure they are the same wheels that you have. I too thought, while I was on their site, if a sensor will fit in the wheel slot and onto the stem. I don't know if I got any measurements of the diameter of the sensors or not. But, I'd sure like to know the outcome on this.
And, I'm also reasonably sure that you and I are not the only ones with those wheels. I suspect there's a few thousand rigs out there with the same wheels and, I also suspect many of those rigs have the TST system on them. Patiently waiting.
Scott
Scott and Karla
SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
lunch surfer
sugar land, tx
Posted: 03/15/12 11:47am Link  |  Print  |  Notify Moderator
I sent you a PM take a look. Let me know what you find. If it works you may want to post the info.
ctc
Thanks,
lunch surfer
My Santa Cruz Superlite is my best vehicle, but my Mandalay 40e is a close 2nd.
Traveling USA looking for the best bike trails and campsites.
ryanallie1
Magalia, Calif
Posted: 03/15/12 12:05pm Link  |  Print  |  Notify Moderator
Hi All.
Well, we don't know what to tell you. We don't have your brand of wheels or Rims. But we do have something pretty close to them.
Ours are "Dicor Crome Wheel Liners", on all of our tires. But the do look an awful lot like yours though. Its sure is not a problem for us to mount our TST Tire Monitoring System on ours.
We have used Valve Extenders on our Duels and on our front Liners also. The Sensors more than clear the rims and not in any way in any danger of being damaged by anything.
Ours was a snap to install. Neither of you bothered to mention which model of the TST Tire Monitoring System that you bought or were thinking about. We bought and Installed the TST 507 System.
We do know that the 510 System has much Larger Wheel Sensors compaired to the much smaller Wheel Sensors of the 507 System..
Which System did you by and wouldn't work for you ? If you tried the 510 System, you could contact TST and request a change, and swap for the Smaller 507 Wheel Sensors.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
mtrumpet
Hamburg, NY
I use short (metal) valve stem extenders with all of my TST Sensors. I was a little leary at first, but no problems as of yet. I've had mine for about a year now.
Mark & Cherie (& Chloe)
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
Snowwing
WA
Posted: 03/15/12 12:12pm Link  |  Print  |  Notify Moderator
I recently installed the new 507 TST system on my Journey with Accuride wheels. After scratching the heck out of the first one I removed the theft deterrent devices. I had to slightly bend the front valve stems to center in the opening - no big deal. I also had to rotate the outside dual valve stems 90 degrees - again no big deal. I did have two bad senders out of 10 and had to send them back. They reported than one was ok and one was indeed bad.
After an initial slight disappointment I really like the system. Incidentally, my toad is parked about 75 ft away and still reads the tire pressures!
Ron
* This post was edited 03/15/12 12:22pm by Snowwing *
2005 Journey 36G
racerchaser
Southwest Missouri
Posted: 03/15/12 12:50pm Link  |  Print  |  Notify Moderator
Nothing like getting quick response. Thanks to all. To answer the question I have the newer 507 system. There have basically been three answers.
1. Remove the outer security shell which reduces the diameter. I tried that but it did not quite fit. Oh so close.
2. Valve extenders. Thanks to those who responded with their experiences.
3. Adjust the valves so the sensors will fit. I had never thought about rotating the outer dual valve 90-degrees, duh.
Since I am in Florida for the winter and leaving in two weeks I am going to go with #2 until I get home and then go with #3. Number 1 is a good option because I do not think there are people out there wandering around looking for sensors they can remove. I doubt the casual passerby would even know what they are.
Fire Up, you can still purchase these but now you will be aware of some of the installation problems. I have no clue if the other systems have smaller sensors. I would doubt it.
Jim@HiTek
Gresham, OR, USA
Posted: 03/15/12 01:28pm Link  |  Print  |  Notify Moderator
Those chrome 'covers' are thin. You can easily use tin snips to cut a larger opening for either the TST or for a brass extender. If you're an accomplished metal worker, the cutout would be hard to notice.
Although the air pressure transmitters don't weigh much, I'd feel more comfortable with an installed brass extender mounted in the wheel. Les Schwab carries several different styles. Tire has to come off wheel to install them.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
supercub
Modesto CA
Posted: 03/15/12 04:15pm Link  |  Print  |  Notify Moderator
Call TST and tell them your problem. They'll help you out, great people to deal with.
Brian
