RV.Net Open Roads Forum: Class C Motorhomes: elec vs hydrolic slides
 > elec vs hydrolic slides
chvyjwm
Senath, Mo USA
Posted: 03/15/12 07:31pm Link  |  Print  |  Notify Moderator
I'm seriously thinking of buying a used c class Jayco with 2 slides. The rv is about6 years old. Knowing that problems can arise from anything I'm asking with type slide is more dependable, electric or hydrolic operated. Not wanting to start a war here, just looking for info on pros and cons. Thanks for any thoughts on this. John
John & Lee   2003 Gulfstream Conquest 22' V10
'97 Wrangler 4 banger 5speed
rolnhome
Casa Grande, Az
Posted: 03/15/12 08:10pm Link  |  Print  |  Notify Moderator
I like electric. No oil, no hoses, no leaks, no springs no pumps, no reservoir tank.
We're in Arizona
past-MIdirector
Michigan
Posted: 03/15/12 08:30pm Link  |  Print  |  Notify Moderator
Like Hyd. since it can move weight with less power and faster. We have 2 slides and jacks. We're set up in half the time as friends with electric. We had jacks only on last rig and in 14 years only had one line leak which was easy to change.
sclark
Minnesota
Posted: 03/15/12 08:23pm Link  |  Print  |  Notify Moderator
I have had both. I like hyd better. Seems to operate quicker. No problems with leaks. (At least so far). Good luck.
2010 Dodge 3500 Crew Cab Cummins
2007 Wildcat 32QBBS
Honda eu3000is Generator
CREATO
Beautiful Harvey N.D.
Posted: 03/15/12 09:00pm Link  |  Print  |  Notify Moderator
Had hyd slides and gear on previouse 5ver had a leak at the manifold blown oring no problem just messy, they are faster than electric hands down. I work with hyd at my job only downfall is not if you will have a leak it is when and where. If on the landing gear not a big problem if on a line to slide cylinder or a cylinder leak now you may have oil inside the rv depending on where the cylinders are located and all the bedroom slides I have seen the cylinder is under the bed not a good place to have oil spraying out. In my perfect world I would have hyd landing gear, stab jacks and electric slides.
I dont rent out space in my brain
Kave2u
Southeastern NC
Posted: 03/16/12 04:49am Link  |  Print  |  Notify Moderator
X2
Kettrell & Sharon
Clinton, NC
2011 Jayco Greyhawk 31DS
chvyjwm
Senath, Mo USA
Posted: 03/16/12 05:06am Link  |  Print  |  Notify Moderator
Thanks for the replies. I'll be finding out today which type is on the rv. Looking forward to the C class side of camping. John
Wills250psd
walnutcove NC
Posted: 03/16/12 05:28am Link  |  Print  |  Notify Moderator
I have had both in the past, currently no slides but when we had them I liked the hydraulic much better. only one suggestion I replaced the cheap looking hoses with good ones I had them made at a local shop that specializes in hoses for equipment of every kind. did not cost much and you keep the originals in case of emergency. jmo will
sonicsix
Jerry n' Cynthia
Posted: 03/16/12 06:29am Link  |  Print  |  Notify Moderator
Had electric in the past and hydraulic on the current unit... I much prefer hydraulic.
SolidAxleDurango
OK, USA
Posted: 03/16/12 06:34am Link  |  Print  |  Notify Moderator
Yet.... Most people continue to drive their cars (with their totally hydraulic brakes and hydro assisted steering) without a second thought... Go figure.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
