RV.Net Open Roads Forum: Tech Issues: Inverter Install
 > Inverter Install
daamac
Posted: 03/16/12 06:09am Link  |  Print  |  Notify Moderator
I'm planning to install a Go Power GP-SW300 inverter and want to check my understanding.
I plan to install the inverter near my battery bank using #10 wire, fused with a 40 amp fuse, and wired through my battery disconnect switch. I plan to run 14-2 with ground romex from the inverter to a dedicated outlet near my TV. I'll use a short whip to plug into the inverter, and connect the whip to the romex in a box. I'll install a remote switch for the inverter near the dedicated outlet.
1) Since there is no connection from the AC output from my inverter to anything but the one dedicated outlet, there is no need for any sort of transfer switch. Right?
2) Can each outlet of the GP-SW300 supply the full output of the inverter (obviously not both at the same time). Yes?
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
garym114
Bluff Dale, Texas
Posted: 03/16/12 08:02am Link  |  Print  |  Notify Moderator
Sounds like you have a good plan.
No transfer switch required. Even though the manual for the SW300 doesn't come out and say either plug can deliver full AC output that should be the case. The two plugs are probably for convenience and go back in the box to one output wire.
mena661
Posted: 03/16/12 08:03am Link  |  Print  |  Notify Moderator
I have the same inverter.
1. Right!
2. Yes.
Trojan L16 6V's 740 Amp-hours
BFL13
Victoria, BC
Posted: 03/16/12 08:18am Link  |  Print  |  Notify Moderator
I just don't like that #10 there, would prefer #6, but it does depend on length.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
smkettner
Posted: 03/16/12 08:58am Link  |  Print  |  Notify Moderator
Good to go, no transfer switch. And yes you get full power from either outlet.
I did end up swapping the wire to #8 to match the #8 of the fuse holder on my GP300.
675 watts solar
daamac
Posted: 03/16/12 12:41pm Link  |  Print  |  Notify Moderator
OK. Thanks to all for replying.
Wherever I happen to park
Posted: 03/16/12 01:58pm Link  |  Print  |  Notify Moderator
Short answers, not the shortest but only one letter longer, same answer to both questions; YES.
In fact the concept of a dedicated outlet powered ONLY by the inverter (I like to use red or orange outlets for this) is what I call a "Poor Man's Transfer Switch" (You switch by transferring the plug)
And the outlets on the SW-300 can handle considerably more than 300 watts, but as you surrmised the max output is 300 watts COMBINED.
mena661
Posted: 03/16/12 04:51pm Link  |  Print  |  Notify Moderator
That inverter comes with four feet of #10 which is ok (I think) but I use #6.
1rosario
Phoenix, Arizona
Posted: 04/07/12 10:01am Link  |  Print  |  Notify Moderator
Hello.
Total newbie and ignorant on this, but trying to get DH to install an inverter, to skip running the generator while driving for kids to watch TV.
ok, this GP-SW300, you speak of, do I only need the 12v? I see there's a 24V also.
Like OP, I only want to run the TV and Directv Box, while boondocking, probably only TV while driving - Vizio 26" LED w/ Wifi Apps.
Also, can I assume, coach (class A) will charge batteries while driving?
DH, probably already knows this - he's an electrician, but for my own educational purposes; we need a switch near the TV outlet to switch between, generator/land power use and inverter use? is that what that switch is for? (I did say I was ignorant on this)
Thanks in advance for the lesson.
smkettner
Posted: 04/07/12 10:49am Link  |  Print  |  Notify Moderator
1rosario,
Yes you want the 12v version unless you have a very rare bus conversion RV that actually uses a 24v system.
Yes virtually all RVs are designed to charge the house battery while driving. Although it can take 2 to 8+ hours for a full charge depending how low the battery is.
You need a transfer switch if you want to integrate the inverter into the existing wiring and power the existing outlet. Switch usually goes close to the inverter or power panel for ease of connecting. GoPower has a provision for a remote power on switch for ease of use if it is installed behind some cabinet.
I power my tv, dvd, laptop and charge small items with a Go Power 300w sine wave inverter.
I mounted the inverter hidden behind the fuse-breaker panel. 12v connects to the main battery feed to the panel. 120v is wired into the entertainment area circuit with an automatic transfer switch. The wiring is very straight forward if you have done any home wiring before. The Go Power 300w has a provision for a remote power switch so with the touch of a button I have instant power.
GP 300w SW $160
Xantrex 15 amp switch $49
So all in maybe $250-$300 for self install.
Morningstar also makes a good 300w inverter.
 > Inverter Install
