mena661
Gjac wrote: I was wondering if you had an old big bulb hydrometer with a long hose that goes deep into the cell, if you just squeezed the bulb a few times would this destratify the acid and be safer than tipping? Doubt it honestly. You don't have to tip it though. Harbor Freight's manual charger does the job very well not to mention that with the typical GC's that everyone uses it's not as big of an issue as with my batteries. BFL's method of applying an equalizing charge after a "full" charge will take care of most everyone's batteries. Now if you're on solar, then you don't need to do any of this unless your solar is not adequate.
pianotuna wrote: Hi RoyB,
You have a shorted or leaking cell. Game over. X2
Trojan L16 6V's 740 Amp-hours
BFL13
Victoria, BC
mena661 wrote: .... BFL's method of applying an equalizing charge after a "full" charge will take care of most everyone's batteries. ...
Not my method but I do it because that is Interstate's method
See note 3 under the tables
http://www.batteries-faq.com/activekb/questions.php?questionid=1
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
RoyB
King George, VA
I thought you guys could work miracles - me devastated... hehe...
I have no idea when it went south. It was probably in Novemeber last year when I did a good Battery Spot Check on the three batteries in the bank.... I'm sort of surprised that the other two batteries didnt suffer from the bad one dropping voltage since they were all three paralleled with my Blue Sea battery switecs.. I guess my 45 amp charger ignored it..
Thanks for the input...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
mena661
Yeah but weren't you doing that before you discovered that info?
BFL13
Victoria, BC
mena661 wrote: Yeah but weren't you doing that before you discovered that info?
Yes but on my 27s which did not gas hardly. I was not expecting to have to do it on my new 6s especially, but got this advice about when I got them so it all worked out Thank goodness for the 1093.
MEXICOWANDERER
las peƱas, michoacan, mexico
Blood pressure 0 / 0
Pulse 0
Temperature: Ambient
"Do we try another shock with the paddles, Doctor?"
mena661
BFL13 wrote: Thank goodness for the 1093. Yes indeed. That really is a very nice charger. Wish they made a PF corrected one that put out 100 amps.
