jerem0621 wrote: Estimated rebuild cost for the 460?
Anyone want to take a jab at it?
I would like to compare it to, say the 6.4 in another thread that cost $15k to rebuild...
Thanks!
Not even close.....better be around 3K if all the work is done at the shop, if you are doing all but the machining $1500.00.
You can buy a rebuilt long block shipped for under $2500.00
Don
Perrysburg Dodgeboy 2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
My guess would be that something else broke before the timing gear. The 460 I built to replace my 400M had a RV cam that made lots of power at lower rpms but didn't like high rpms because of the long stroke that comes with a 460.
There is one thing I can say about that motor with RV cam, milled heads, bored 30 over, MSD ignition, Edelbrock manifold and carb, custom exhaust, built C6 with RV stall converter and 4.10 rear end it would pull down a house if you could keep the tires from burning off and fuel in the tank .
Denny
edited 03/18/12 12:38pm by Denny & Jami *
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
Denny & Jami wrote: My guess would be that something else broke before the timing gear. The 460 I built to replace my 400M had a RV cam that made lots of power at lower rpms but didn't like high rpms because of the long stroke that comes with a 460.
Denny
Exactly my thoughts and that I don't really need (now don't want) a
diesel to be able to rip your teeth out with throttle stomping...
-Ben Picture of my rig
The 460 will likely cost about 1/3rd or less of what a late model diesel V8 (DuraMax or Powerstroke 6.0, 6.4, 7.2) would cost to do a complete rebuild.
Perrysburg Dodgeboy wrote: Not even close.....better be around 3K if all the work is done at the shop, if you are doing all but the machining $1500.00.
Don
Don`t forget to add in the cost of injectors and a highpressure pump!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
A crate motor from Summit might be the easy way if $$ are right. (I haven't looked) We launched one at high RPMs a few years back and the rebuild cost did not make sense - there was very little to salvage. We spent a few dollars more for a better build and ended up with a much stronger truck.
Larry and Debbie Kruzan
We never turn a corner without wondering in amazement at God's creation!
Denny
Actually, the Ford 460 has a stroke of 3.85", which is short for a big block. In comparison, a 350 Chevy has a stroke of 3.48". With the Ford 460's stroke only being roughly 3/8" longer, it should be especially adept at high rpms because of it's stroke.
