DaButcher
texas
While using the on-board water pump I get a small amount of water coming out of the city connection, causing the pump to run two or three times an hour. Is there a check valve somewhere or what keeps the two separated?
06 Keystone Sprinter 299RLS
2011 F250 6.7
NRA Life Member
Artum Snowbird
Campbell River, B.C., Canada
There is a check valve built into the hose connection. Take off the screws and pull it out, unscrew the check valve and replace it. About a 3$ item. Many of these check valves get buggered by people pushing in the check valve after they have pressurized their system with antifreeze. Correct procedure is zero pressure in system, push check valve and have someone start pump for a few strokes only. Once pink comes out, release check valve.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
SWD
Land of Living Skies
Artum Snowbird wrote: There is a check valve built into the hose connection. Take off the screws and pull it out, unscrew the check valve and replace it. About a 3$ item. Many of these check valves get buggered by people pushing in the check valve after they have pressurized their system with antifreeze. Correct procedure is zero pressure in system, push check valve and have someone start pump for a few strokes only. Once pink comes out, release check valve.
X2
DaButcher
texas
Will replace that valve, thx for the quick response
Fabguy
Auburn, Washigton
Before you go through all that, just hook up the hose to the city water connection and run some water through the check valve. Quite often it will re-seat and seal up properly.
Jeff
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Dual Cam HP
Pulling a 2004 Sprinter 274 RLS
Grillmeister
BBQ TOUR USA
DaButcher wrote: Will replace that valve, thx for the quick response
Try to find a brass / bronze one if you can, the pot metal ones only last a few years. My last good one was about ten bucks from a local RV store.
Show me the GRILL and STAND BACK!!!!
DaButcher
texas
It's been leaking a couple years, mostly use city connection so haven't worried about repair. Have a dry camp planned so didn't want to worry about turning the onboard pump off and on.
Fabguy wrote: Before you go through all that, just hook up the hose to the city water connection and run some water through the check valve. Quite often it will re-seat and seal up properly.
DaButcher
texas
I did find a brass fitting and says has a brass seat so maybe this one will last.
Grillmeister wrote: DaButcher wrote: Will replace that valve, thx for the quick response
