RV.Net Open Roads Forum: Class A Motorhomes: water in fuel light on.
 > water in fuel light on.
ColeAve
Maryland
Posted: 03/19/12 08:19am Link  |  Print  |  Notify Moderator
We have been in cape hatters and are on the road home and we have a water in fuel light on.our rig is a Newmar ventanna le. Any one know what this.means? We didn't have this on the way down and have not stopped and put new.fuel in? Thanks.for.any.help in advance..
Gadget Guy
Calgary
Posted: 03/19/12 08:31am Link  |  Print  |  Notify Moderator
The first fuel filter has a sensor that detects water in the bottom of the filter. Open the petcock on the bottom of the filter and drain some fuel in a container and see if you have any water. The water will come out first because the fuel will float on the water. If no water is present then check and make sure that the electrical connection is good. I had the same problem travelling in some wet snow, I removed the connection, cleaned it and sprayed the plug with some contact cleaner, plugged it back in and all was good.
skipnchar
Topeka or somewhere else
Posted: 03/19/12 08:45am Link  |  Print  |  Notify Moderator
