RV.Net Open Roads Forum: Passing through Canada to save 120 miles?
Open Roads Forum  >  RVing in Canada and Alaska
 > Passing through Canada to save 120 miles?
Mickeyfan0805
SE Mass
Posted: 03/19/12 09:47am Link  |  Print  |  Notify Moderator
We're headed from MA to MI this August. We can save 120 miles by traveling through Canada, but would have to deal with customs into, and out of, Canada (as well as having to arrange a 1-night stopover in Canada). Is it worth the hassle to save the miles, or are we better off to simply go around the lakes and stay in the US?
SWD
Land of Living Skies
Posted: 03/19/12 09:50am Link  |  Print  |  Notify Moderator
6 of one, half a dozen of the other. Customs not usually a hassle coming in to Canada and usually good going back to the US. Fuel prices will be higher though, so...in the long run I'd say stay on the US side.
skipnchar
Topeka or somewhere else
Posted: 03/19/12 10:33am Link  |  Print  |  Notify Moderator
I've never taken more than ten or fifteen minutes to clear customs in either direction if you're careful about WHERE you cross when when. 120 miles wold take a lot LONGER than that to travel. Guess it depends on how much value you put on saving an hour or so on the trip. One OTHER thing to keep in mind is you're apt to run into lower speed limits in the North side of the boarder so SOME of that time savings may not actually be there.
n7bsn
Yes
Posted: 03/19/12 10:50am Link  |  Print  |  Notify Moderator
skipnchar wrote:
I've never taken more than ten or fifteen minutes to clear customs in either direction if you're careful about WHERE you cross when when. ....
I take it you actually seldom cross. Back in the working days I crossed weekly, often with my choice of crossings (all lower main-land BC). Even with monitoring for crossing time (AM 1130) I have seen crossing times as short as 5 minutes, and as long as 2 hours. I've even seen long times during off period, that is few gates open, with unexpected heavy traffic.
Back to the O.P. I wouldn't, it will cost you more in gas (higher prices near and across the border), plus border crossing time
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
shum02
Burlington ON CDA
Posted: 03/19/12 11:38am Link  |  Print  |  Notify Moderator
Well I'd fill up before hitting this side of the border and then save the 120 miles. If your truck can't do an easy 120 miles without fuel your tank is to small!
Depending on what crossing and the date and time of the crossing it could only take minutes.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
garym114
Bluff Dale, Texas
Posted: 03/19/12 12:00pm Link  |  Print  |  Notify Moderator
Do you have your passports? Required to enter the US.
63-Coupe
Ontario
Posted: 03/19/12 12:01pm Link  |  Print  |  Notify Moderator
Assuming from your message that you are crossing into Canada at Buffalo or Niagara Falls and going back into the U.S. at either Detroit or Port Huron you will be on divided highway for almost the whole way if you take QEW/403/401 & maybe 402 the speed limit will be 100kph or approx. 62 mph. There will be a short urban stretch in Windsor or Sarnia just before the U.S. border.
Fill up in the U.S. just before you cross and that should get you all the way through Canada. It would be about 250 miles to Detroit and a little shorter to Port Huron.
Don't forget to factor in the bridge tolls at the borders.
turninghawk
Orlando, FL
Posted: 03/19/12 12:19pm Link  |  Print  |  Notify Moderator
I'd stay on the US side.
Also, why would you have to have a 1-night stopover in Canada?
JN_B
Calgary, Alberta
Posted: 03/19/12 01:07pm Link  |  Print  |  Notify Moderator
I`d stay in the states.
Look at it from the border patrol`s side.. Why did this guy cross for a couple hours then back into the states (logics aside). More prone to getting searched/delayed if it`s an odd situation.
2003 GMC Sierra 1500HD SLT
2010 K-Z Spree 318BHS
shum02
Burlington ON CDA
Posted: 03/19/12 01:18pm Link  |  Print  |  Notify Moderator
Enhanced drivers licence will do as well.
