doggoneflyball
Looking to purchase a gently used B+ or C Rv with bed over cab, rear corner bed, garage storage and a chair by the entryway. No longer than 25 feet.
So far have considered the Coachmen Prism M220, Forest River Solara 24, and the Thor Chateau.
Can anybody offer advice or pricing on these?
I currently have a 2000 Dynamax Isata Sport coach.
Nancy in Florida
Coach-man
I recently traded my class A for a Prisim, I think it is great, I get 14 MPG towing a Ford Fusion, it has enough room for DW and I, along with the two dogs and a cat! The ride is good, (I do miss being up above it all with the A), but it is comfortable even on the interstate. Hope this helps!
robsouth
Near Atlanta, GA
You are going to hate that rear corner bed when it comes time to make it up.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
pnichols
Santa Cruz Mountains
Quote: You are going to hate that rear corner bed when it comes time to make it up.
I have a rear corner bed in a 24 foot Class C and making it up is no problem at all. If I were you I wouldn't consider it as an issue.
We leave a permanent heavy cover on the mattress. What we do makup - very easily - is a 2 inch foam topper on top of the mattress. The DW made a fitted bottom sheet for the topper and a non-fitted top sheet for the topper. We wash both of these after every trip. You can lift the corners of the foam topper to quickly hook the fitted sheet corners on the topper and tuck the non-fitted sheet under the window side and foot of the topper. We hardly climb up onto the bed at all to do this - most of this can be done just standing at the foot of the rear corner bed. The 2 inch foam topper also makes for a very comfortable bed!
Phil, 2005 E450 Itasca 324V Spirit
Al Fresco
North Idaho
I wouldn’t let the corner bed arrangement be the deciding factor governing your choice. I use one of those extended-reach grippers (see here) to straighten the sheets and blankets in the far corner of the bed. The gripper adds about two and a half feet to your reach and greatly facilitates daily bed making in units with otherwise hard-to-reach corners. With this device, you can easily straighten out the bed each day from the unobstructed side.
Dakzuki
Carnation, Wa, USA
robsouth wrote: You are going to hate that rear corner bed when it comes time to make it up.
There are a zillion ways around the possible hassle of making the bed. The compactness of it makes up for it IMO.
2011 Itasca Navion 24J
95 Chinook Premier
Dusty R
Charlotte Michigan 48813
I would think that making the bed in the crows nest would be harder, but my wife does it every day without complaining.
Coach-man
Dakzuki wrote: robsouth wrote: You are going to hate that rear corner bed when it comes time to make it up.
X2!!!
travisc
Pacific NW
We have a Winnebago Access- the model says 24' But measures out at 25'1" it works for our small family- no slides- corner bed. Takes up two parking spots at the nearest wallmart.
Winnebago Access 24V
gerrym51
unknown
Forest river solera 24MS. ms is a new model walk around murphy bed
