RV.Net Open Roads Forum: Fifth-Wheels: Splendide Washer/Dryer laundry detergent choice
 > Splendide Washer/Dryer laundry detergent choice
Salty Dog
Upstate NY
Posted: 03/19/12 02:46pm Link  |  Print  |  Notify Moderator
First time owner of a 2100XC Spendide unit. What laundry detergent and fabric softener seems to work rhw best with these units? Thanks, Mike
Wife, kids, somebody else's kids, dog, kitchen sink
Cleverly disguised as an adult.
missourijan
AZ, TX, AR, IN, MT, then back to CA for the summer
Posted: 03/19/12 02:50pm Link  |  Print  |  Notify Moderator
Any compact washer requires the HE detergent, any fabric softner, just use less. I have a Whirlpool compact and use the Costco Kirkland brand HE detergent.
SuperDutyFiver
Long Valley, NJ, USA
Posted: 03/19/12 03:00pm Link  |  Print  |  Notify Moderator
Stacked Maytag apartment front loaders here-using Amway SA-8 since day one...
1 PSD 4x4 Custom Tow Vehicle-the 550
1 PSD 4x4 SUV-the X
2 PSD 4x4 Duellies-F350&F250HD
36' Carriage Carri-Lite
32' Open Triaxle Dovetail
22' Gooseneck Dump
E450 PSD 4x2 Chassis Cab
E550 PSD 4x2 Cube Van-The Beast
RIP-Prowler 345Y LSI-THANKS SUPERSTORM SANDY...
past-MIdirector
Michigan
Posted: 03/19/12 03:51pm Link  |  Print  |  Notify Moderator
we use the Dollar store both on the road and at home. Never had a problem. There are only a couple of companies that make all those brands so if you follow directions 2 tablespoons of soap and a 1/2 cap of softener then add a cap of warm water into dispenser with softener.
ploiselle
South Shore, MA
Posted: 03/19/12 06:19pm Link  |  Print  |  Notify Moderator
Tide he
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
tiptoes33
Hutchinson
Posted: 03/19/12 06:32pm Link  |  Print  |  Notify Moderator
I have used Purex soap for the last 2 yrs with my Splendide, never a problem. As others have said, use less soap and softner, should work fine.
rattleNsmoke
Western Conn.
I'm gonna ask a dumb q 'cause i have a Splendide stackable and we'll be using the heck outa it this season......What is an 'he' detergent?
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
The Mad Norsky
Yankton, South Dakota
Posted: 03/19/12 06:48pm Link  |  Print  |  Notify Moderator
Mike
High Efficiency
H.e usually marked on the front of the bottle/box. Takes less of this detergent to do the same job.
The Mad Norsky, Doll, Logan, Korey & Rocky
2011 Ford F350 Power Stroke dually
RV'ing since 1991
We never know where we're going till we get there!
portablevcb
Tijeras, NM
Posted: 03/19/12 07:27pm Link  |  Print  |  Notify Moderator
We loved the Purex 3 in 1 sheets. Cut them in half or thirds. Throw some in a zip loc bag. No liquids to mess with. But, can't find them now.
2009 Dodge 2500 Double Cab Cummins
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
louiskathy
Oregon (presently)
Posted: 03/19/12 08:03pm Link  |  Print  |  Notify Moderator
Do NOT use dryer sheets in the dryer. Those sheets cause problems... do a search and you can read all about it. Just do not use washer or dryer sheets.
Liquid HE - and it does not matter what brand. I like Whisk. HE comes in regular, 2X and 3X concentrations. Use sparingly. A little goes a long way.
And I always put my washer on "EXTRA RINSE" because getting the soaps out of the clothes is important.
And once you start using the washing machine... Wipe the inside dry with one of those quick dry towels(and the inside of the door) and don't forget to wipe out the pocket in the rubber gasket.
There's a rubber gasket just inside the door...grey and "U" shaped. It has 3 holes in it for water to drain out of the gasket. If the gasket gets plugged, and the water can't drain... it will get grungy and moldy in there. (Ask me how I know....) So wipe it out when you're done for the day.
I add one or two scoops (coffee scoop size - 2 Tablespoons or so) of BORAX laundry booster (20-mule team borax) to each load. Just put the borax in before you put the clothes inside the washing machine. If I had done this from the beginning instead of two years too late, I would not have had a problem with odors in my washing machine. Front end washer's are well known for odor problems. They sell special tablets to put in and run the machine through a wash cycle to rid it of odors but it takes a few times to get the odor gone. Those tablets are not cheap. 20 Mule Team Borax IS CHEAP compared to dealing with odor problems later.
AND... when I go to dump the black tank... I use the HE laundry soap and the borax together to soak the toilet bowl and take out the stains before I do the final flush and rinse the tank. I know it works well for that.
So... you put water in your bathroom sink( to plug the air).
You fill the toilet bowl with water (to plug the air) and put 1/4 to 1/2 of a cup of HE laundry soap and 3 coffee scoopfuls of 20-mule team borax into the toilet bowl and swish it around real good. Then shut the gray valve and open the black tank valve. (You need to have your black tank almost Full when you do this.) With the air blocked in the sink and toilet, the tank will need to pull air from the air vent on the roof...which you WANT it to do.) You'll hear a WHOOOSH and get a strong surge that will come out of the Black Tank as it pulls the solids from the bottom of the tank for a good cleaning. (You better of had your connections good and tight on the sewer hose.)
When it gets down to a trickle.... now close the black valve. Flush your toilet and send the HE soap/borax into the black tank. NOW Put lots of water into the tank with the tank sprayer in the tank (if you have one) or a hose/tank sprayer down the toilet and give it a good amount of water. Now pull the blank tank valve again and hose it out until it's good and clean. you're done. CLose the Black Valve and open the gray if you're hooked to sewer.
As far as the Gray tank... I'll close the gray valve for a load or two of laundry about once a month and then open the valve to flush it. The HE laundry soap and the 20 mule team borax I put into the the washer will end up in the gray tank. Just don't forget to open that gray valve before your gray tank fills up with laundry water.
* This post was edited 03/19/12 08:09pm by louiskathy *
Kathy
