We have a 2003 Jayco pop-up with the storage trunk in the front. The problem is that it takes 10 minutes to unlock the darned thing. It has 3 spring loaded locks that you turn to get it open. But it's not a "keyed" lock. The key is this cylinder with 3 internal ribs that are supposed to catch on the drum as you turn it. "Works like a charm!!" First, you don't even know which way to turn it to unlock it(trial and error) and second, about 60% of the time the key does not engage the drum. Like I stated in the subject line..."Who's bright idea was this"? What a pain in the tucous(sp)
edited 03/19/12 04:30pm by jbird68 *
I think they were originally designed by a Buddest Monk as a mind relaxing Zen cleansing ritual. Sort of a "wax on...wax off" kind of thing!
I'm assuming that the locks are sticking and won"t turn? If that's the case. Spray some WD-40 inside the lock and around all the latches when you get it open.
I just had to do that with my new TT. Just getting the key in the key slot was a chore. I chalked it up to sitting out in the lot and not getting much use. I did the same to all my storage compartment locks as well.
Never had any issues with them, and honestly they aren't so complicated to figure out.
What I loved about the Jayco front storage trunk is that I never had ANY leaks or water issues, unlike some other companies with front storage trunks that could never figure out how to keep that area dry.
2011 Honda Pilot
2009 Jayco 1207
Eat at Mary's Hot Tamales - Magnolia Ave, Knoxville, TN!
