shadet
Erie
didnt see one - just wires going form the the batt to inside of camper
pianotuna
Regina, SK, Canada
Hi,
If there is a disconnect switch, then the converter can't recharge the battery.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
shadet
Erie
I unplugged the camper too so it would be charging anyway. Sorry - new to this
shadet
Erie
It was plugged in the entire time during walkthru today and for about a 1/2 hour at home b4 it started going off
MALE*RN*777
Western MD, USA
FYI....Cleaners, perfumes, hair spray, etc. can also set off the detectors.
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife ,The Boy ,Girl 1 ,Girl 2
We are Blessed.
FireLieutenant72
Ohio
I just got a new hybrid also, mine was doing same thing. they replaced it on warranty. said some were defective. may wanna contact them
TJ Melissa Cole(7,son) Kelsey(4,daughter)
2009 Silverado Z71 ext cab 5.3 .373 tow package
Equilizer hitch and prodigy 3 controller
2011 KZ Coyote 23CKS (Sold)
2014 Viewfinder 28bhss
pianotuna
Regina, SK, Canada
Hi,
It takes a long time to charge even a single battery.
"The chart above shows the amount of time it took a PD9155 (55-amp) converter set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
MudChucker
Niverville Manitoba
this used to happen to a unit I had with a front window, I could leave the window open and fold down the stone protector and get down the road, the exhaust from my truck would get in around the deflector and the oxygen sensor in the trailer would sound off...
as mentioned, very likley a dead battery
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
Chuck_S
Broadview Hts, OH, USA
Unless the battery is disconnected after charging the parasitic draws in the trailer, including the LP detector, will kill a Group 24 battery in two weeks. The LP detector will start beeping if the voltage gets too low.
I've not seen a battery disconnect switch as stock on a hybrid which means you must add one, or go to the hassle of disconnecting the ground wire every time you park without power. Boat supply stores have many weatherproof switches. Just need an On/Off version. Since you're not switching the ignition on a boat use the Negative wire to completely isolate the battery from the camper.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
Triguy
SE Wisconsin
shadet, it might help if you told us what year, make and model trailer you have? The newer Roo/Shamrock built in late 2012 have manufacturer-installed battery disconnects.
Its a very useful mod. Costs about $30 or less to add one yourself.
2012 Shamrock 233S, P3, Equal-i-zer
2008 Toyota Sequoia 5.7L 4WD
