RV.Net Open Roads Forum: Class A Motorhomes: Sealed or Unsealed Coach Battery's?
 > Sealed or Unsealed Coach Battery's?
Gappy
NE Indiana
Posted: 03/19/12 07:38pm Link  |  Print  |  Notify Moderator
I need to replace my 3 coach battery's
and I am inclined to buy sealed battery's instead
of the unsealed ones that I will be replacing.
Does it matter?
Tom
2013 Silverado 2500 Duramax Crew LTZ Z71 4x4
2013 Winnebago ONE 32BH
CapnMorgan
Asheville
Posted: 03/19/12 08:16pm Link  |  Print  |  Notify Moderator
It might. Can you modify the charging voltage that your charger is sending to the batteries?
John and Robin
2000 / Holiday Rambler / Imperial
mena661
Posted: 03/19/12 08:22pm Link  |  Print  |  Notify Moderator
X2
Trojan L16 6V's 740 Amp-hours
sunkatcher
Fulltimer
Posted: 03/19/12 08:32pm Link  |  Print  |  Notify Moderator
Sealed batteries just make it a bit harder to check the liquid level it won't eliminate the need for servicing.
Ron
masa4u.com
Gappy
NE Indiana
Posted: 03/19/12 08:35pm Link  |  Print  |  Notify Moderator
Yes, it has a xantrex control panel.
RFCN2
MT
Posted: 03/19/12 09:03pm Link  |  Print  |  Notify Moderator
Sealed batteries also mean no spill of acid and no fumes. Two advantages.
RFCN2
Country Coach
Jeep Wrangler Unlimited
tahiti16
Camarillo, CA
Posted: 03/19/12 11:07pm Link  |  Print  |  Notify Moderator
If you are generally plugged in and seldom dry camping probably doesn't make any difference. Sealed batteries are not the same as AGM batteries. The sealed ones are still "wet" batteries you just can't do anything about lost water. So heavy use will probably give you a shorter life with sealed.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 03/20/12 12:13am Link  |  Print  |  Notify Moderator
My coach batteries are not sealed! My chassis battery is sealed!
jerseyjim
New Jersey
Posted: 03/20/12 06:23am Link  |  Print  |  Notify Moderator
In my experience, it really doesn't matter. 3-5 years,either one.
wingtraveler
Alamo, Texas
Posted: 03/20/12 08:14am Link  |  Print  |  Notify Moderator
Yes you can do something about the water loss. Add mineral oil to the top of the batteries. I haven't had to add water in my Trojans for over a year. 2.5 oz/cell
As a benefit there is no mess around the batteries from the mist escaping.
08 Discovery 40x
08 Hyundai Sonata GL toad
08 Honda Goldwing
