Does anyone know the code to program my RC65 remote to operate
my Vizio Led Lcd TV ?
I had contacted DirecTv,but all the codes given were no good.
Thanks for any & all help.
Siggy
The listed codes on their website are
11756 10864 10885 11499
If one of them doesn't work, try StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
1 for Televisions
2 for "AUX 1" devices - VCRs or DVDs
3 for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key.
Bob and Honey Couch
Miniature dachshunds Tinker and Dusty
2008 Keystone Everest
2007 Dodge MegaCab w/ 5.9 Cummins http://boggythicket.blogspot.com/
