five'er
Canada
fla-gypsy wrote: Better than having some idiot dump it on the ground and let it run in which does happen from time to time.
To be honest.. There are dump stations where this is how it's done! There is a park in Alberta in Kananaskis country that used to be that way (maybe not anymore) I think it was Mt Kidd. Anyhow.. There was no way to dump with a hose! Had me scratching my head the first time.. You simply positioned your drain over a grate and fired away.. After you were expected to rinse it down with the supplied hose.. Actually a really handy way to do it IF it's set up that way. Maybe those idiots are just sheltered? I don't know.. trying to give them a break.. maybe they don't deserve..
papa peter
Ripon, CA
Executive wrote: Go to the Jackson Rancheria in Jackson California. When you pull in, you get assigned your spot, then you pull up to the dump station and THEY have ATTENDANTS that empty your holding tanks BEFORE you go to your spot....Dennis
Last time I was there they also gave me their black tank chemicals to use rather than my own.
2012 Winnebago Vista 26P - 2012 Jeep Limited Jet Liberty
FrankoToo
Escondido, CA
papa peter wrote: Executive wrote: Go to the Jackson Rancheria in Jackson California. When you pull in, you get assigned your spot, then you pull up to the dump station and THEY have ATTENDANTS that empty your holding tanks BEFORE you go to your spot....Dennis
It's my understanding that Racheria is on their own septic system. They have you dump first (into city sewer?) to get rid of any chemicals that might contaminate their system and then use their chemicals only while in the park to keep the system contaminate free.
FrankoToo
2012 Heartland Cyclone 3612 HD
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
mlts22
Austin, Texas
Now that would be cool on one hand -- just pull up to a grate and let 'er rip. However, I'm sure the smell would be overwhelming if there wasn't a flushing system in place.
Jim Shoe
Amelia, OH
I remember seeing an article with pictures about some company that was selling dump stations including installation to anyplace that didn't normally have one. I think they were targeting rest stops on expressways and gas stations. There was a charge to the RVer for using it (a buck or two, if I remember correctly) and your charge card didn't come back until you put everything back where it belonged. And the company that was selling them would come by and empty the tank from time to time. Seems like I saw the article a couple of years ago, but I haven't seen one of the dump stations yet, or didn't notice it.
Retired and visiting as much of this beautiful country as I can.
JcoFS3500
East Central OK
five'er wrote: fla-gypsy wrote: Better than having some idiot dump it on the ground and let it run in which does happen from time to time.
Yep, one county fairgrounds where we stop periodically has a 3'x3' concrete curb surrounding a manhole cover sized hole and you drape your hose into the 3'x3' area and let'er fly. I remember a couple rest areas that we stopped in that had a recessed area beside the drive and you just pulled up close and pulled the handle. No hose necessary. Very convenient but not very common.
The ones that get me are the ones with the drain connection 6" above ground and you have to "walk" the sewage thru the hose to get it up to where it will drain.
'93 Jayco FS3500 TT behind a '92 Dodge D250 powered by 5.9L Cummins
'94 Vogue Prima Vista powered by 8.3L Cummins w/ 6spd Allison
wbwood
Mooresville/Troutman, NC area
What I was thinking too....probably worth the cost to replace them every once in a while than to have to continuously clean up after others. Plus he let two dump at the same time into one hole. Pretty cool!
Brian
RVing Illustrated
2013 Thor Chateau 31L
five'er
Canada
wbwood wrote: Plus he let two dump at the same time into one hole. Pretty cool! DING DING DING DING!!! We have a winner!!! I bet that is the TRUE reason why it's the way it is!!
shutdown
In The Dog House
yep, thats a classic double dumper trick. I just hope people remember to hang up the hose when they are done....or you may get some 'feedback'.
This is a great idea so long as people aren't pigs!
MALE*RN*777
Western MD, USA
Wow that was great.
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife ,The Boy ,Girl 1 ,Girl 2
We are Blessed.
