RV.Net Open Roads Forum: step light staying on 97 damon intruder
 > step light staying on 97 damon intruder
edsuph
Illinois
Posted: 03/20/12 06:19am Link  |  Print  |  Notify Moderator
I just purchased a 97 damon intruder and last night the light was off. this am when i got ready to leave the step light stays on when steps are in. The way i understand it the light is supposed to be on when steps are out? they are Kwikee electric steps.
Ed
A bad day RVing is better than a good day working.
dougrainer
Carrolton, Texas
Posted: 03/20/12 06:22am Link  |  Print  |  Notify Moderator
You are correct. The odds are, the previous owner or Damon installs a seperate light switch. The Kwikee step module and instructions have a provision for a seperate light control switch and some OEM's install that extra switch. Try flipping some switches by the entry door to see if the light goes out. Doug
edsuph
Illinois
Posted: 03/20/12 06:27am Link  |  Print  |  Notify Moderator
I tried all of the switches by the door. it is strange because the light is on when step is in and not on when out???
thanks for the quick response. If i take the bulb out it should not cause any problems right?
MustangGT
Athens, Alabama
Posted: 03/20/12 09:46am Link  |  Print  |  Notify Moderator
My light stays on only when steps are out AND the switch is on. I don't know what the switch does when engine is off and stairs are wherever.... hmmmm, something else I need to figure-out on this thing.
Its not practical, but I'd like the light on when the stairs are stored while engine is running, but RV is in park and I'm in a hurry to get outside. Maybe that is the reason it was apparently re-wired.
A few times I've almost broken a leg by not giving the stairs time to deploy when the door is opened from inside. I think my wife and son have done the same thing.
Could be a genetic flaw, I guess. Or something in the RV water.
Mark, Jean, Paul & Lizzy (the mutt)
1997 Fleetwood Southwind Storm 34LS
Thirsty, noisy & clunky. She ain't pretty, but she sure is fun!
"Aerodynamics are for people who can't build engines." Enzo Ferrari
edsuph
Illinois
Posted: 03/20/12 11:26am Link  |  Print  |  Notify Moderator
the light comes on when steps are in not out though and when i went back out to check it the light was out????
dougrainer
Carrolton, Texas
Posted: 03/20/12 04:52pm Link  |  Print  |  Notify Moderator
One thing I forgot. You have a 1997 model and I will bet, someone has changed the motor or control kit and you have the new style kit and they found that when they opened the door the step retracted and when they closed it extended because they DID NOT read the directions for the updated control kit which requires the door magnet to be changed also which caused the step to operate in reverse. There are RV'ers on this forum that ran into that problem and instead of READING the directions, they rewired the motor to get it to operate correctly and then that would cause the light to operate like yours. Doug
MartinDYN
SoCal
Posted: 03/20/12 05:23pm Link  |  Print  |  Notify Moderator
Your Damon has a Demon
'70 Jeep CJ5 + Sears Tent(Sold)
'70 Jeep + '63 Field and Stream Trailer(Sold)
'86 Ford F250 + Lance Camper(Sold)
'73 Dodge Sportscoach Class A(Sold)
'86 GM Eleganza 31' Class A(Sold)
'99 Suburban + '74 AS Landyacht(Sold)
'97 Damon Intruder 35' DP CAT
edsuph
Illinois
Posted: 03/20/12 06:58pm Link  |  Print  |  Notify Moderator
thanks Doug I wonder if that is what happen. Does the light go out after it has been on for awhile?
sjholt
Henderson, NV
Posted: 03/21/12 05:08am Link  |  Print  |  Notify Moderator
If you crawl under the step, you will see a wire going to the light and it can be separated to disconnect the light.
That is what I did a long time ago as I really didn't need that light.
HTH
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
dougrainer
Carrolton, Texas
Posted: 03/21/12 06:37am Link  |  Print  |  Notify Moderator
NO, and it will when the battery goes dead Doug
