RV.Net Open Roads Forum: Fifth-Wheels: Black water flush not letting water in.
 > Black water flush not letting water in.
rugmanrn
Macon, GA
Posted: 03/20/12 08:53am Link  |  Print  |  Notify Moderator
Tried the black water flush on my new 2012 5th wheel this weekend for first time. No water is going in. There are now valves to turn etc, it should be just hook hose and turn on according to my dealer. I have heard from others that there is a check valve that may be stuck. This is first time being used. Anyone had this problem and no any tricks or soulutions?
Thank you
Mark
Macon, GA
TV 2008 Ford F350 SD
2012 Columbus by Palomino F320RS
Reese Revolution kingpin
greende
Syracuse,NY
Posted: 03/20/12 09:00am Link  |  Print  |  Notify Moderator
Sounds like check valve is stuck.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
therink
Rochester
Posted: 03/20/12 09:08am Link  |  Print  |  Notify Moderator
Could be that the vacuum breaker/check valve was installed backwards (Gilligan?)
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
rugmanrn
Macon, GA
Posted: 03/20/12 09:12am Link  |  Print  |  Notify Moderator
any way to check that? ha get it!?
Seriously, do I have to take panels down to get access to the tanks? Is this something I could be able to do?
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 03/20/12 09:23am Link  |  Print  |  Notify Moderator
I had the same problem with my new fifth wheel last year. The lines to the flush were installed backwards at the factory. This means when you connect the water line to the flush, the water pressure closes the backflow preventer. You can either switch the lines at the black water tank if you can reach them or find the backflow preventer & switch the lines there. In my case the backflow preventer is located behind the shower. There is an access panel there to access the shower faucet for service. If yours is located there you can make the switch. Otherwise, I would take it back to the dealer. Of course, if your dealer is close by, then the easiest thing is to return there.
therink
Rochester
Posted: 03/20/12 09:32am Link  |  Print  |  Notify Moderator
On my fiver, the valve is located under the sink in the bath. Basically, it should be located somewhere over your black tank, usually where it can be accessed.
Old-Biscuit
Across the USA
Posted: 03/20/12 10:03am Link  |  Print  |  Notify Moderator
Look inside opposite of where you hook up hose outside......
I have to remove kitchen drawers to get at vacuum breaker on ours......then would have remove a section of underbelly to get at where it goes into tank. PITA!
MyakkaTT
Bradenton, Florida
Posted: 03/20/12 10:23am Link  |  Print  |  Notify Moderator
Ours was full of sawdust and clogged the flush head...Had to remove the head for the tank to clean.
2007 McKenzie Starwood SL 31 BHD
2006 Dodge Ram 2500, Quad Cab, 4x4, CTD
My Wife: Dawn
Myself: Scott
Our Dog: Our new Fur Kid, Kylee
Our Photos
Trailer Mods
"Quietly Making Noise"
Bois D'Arc
Oklahoma
Posted: 03/20/12 12:24pm Link  |  Print  |  Notify Moderator
Our vacum break valve was istalled backwards at the factory. I cut it off the lines, turned it around and re-installed. Works fine now. Ours is located under the bathroom sink.
* This post was edited 03/21/12 07:11am by Bois D'Arc *
2008 F350 Crewcab Lariat DRW
2011 385X12 XLR
2010 Clubcar Carryall mounted with dog box
Zach, the spoiled rotten English Setter
Holly, the really spoiled rotten German Shorthair Pointer
BrokenElbow
Valencia, CA
Posted: 03/20/12 08:41pm Link  |  Print  |  Notify Moderator
As noted by others, you have to find out where the check valve is located. On mine, it was behind the shower wall. I took it to the dealer and they took off the bath spout panel, reached up in there and replaced the plastic check valve with a more expensive brass unit....no more problem. If it's under warrantee, I'd let the dealer do it.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
