RV.Net Open Roads Forum: Fifth-Wheels: Maybe not meant to go!
 > Maybe not meant to go!
rattleNsmoke
Western Conn.
Posted: 03/21/12 06:58am Link  |  Print  |  Notify Moderator
I'm interested in finding out just what grounded the OP's 6.4? I doubt anyone following this thread really cares about someone else's fuel mileage. 12mpg or 16mpg, they all suck.....but most of the time get the job done. I can't believe how positive the OP's attitude was when his travel plans were crushed. I'd be steaming mad. Many of us wait and plan all year long for that BIG vacation. That guy has incredible character. Good luck my friend! Please keep us in the loop.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
rmalik1
Pittsburgh,Pa.
Posted: 03/21/12 06:59am Link  |  Print  |  Notify Moderator
It's the rear end,and you can get a 4:10 but max 5th wheel weight is about 15,000 lbs.
* This post was edited 03/21/12 07:56pm by an administrator/moderator *
2012 Cedar Creek 36RE w/ Level Up
B&W Turnover w/ 18k Companion Hitch
08 Ford 350 Lariat DW PSD Crew Cab Long Bed 4:30
RoadLife
New Mexico
Posted: 03/21/12 07:17am Link  |  Print  |  Notify Moderator
rmalik1 wrote:
When planning this trip things kept going wrong! As if fate wanted us to stay home.
I'm going to keep my eye out for things that may have happened along our route within our time frame!
!!!!That is sorta what happened to us. We were supposed to go southwest for the winter but had to stick around for an upcoming minor surgery. So we rambled around Florida for the winter instead - the weather was fabulous. The Southwest had major snowstorms.
Now our trip to Alaska has been delayed for about three weeks due to another upcoming unexpected minor surgery. I'm keeping my eyes on the news this next month.
I think someone is keeping an eye out for us.
ROADLIFE
RoadLife USA 2013 Blog
2003 40' Allegro BUS - 2 slides
2013 Ford F150 XLT 4X4 OffRoad 2009 RAV4
Shasta - Australian Shepherd; Boomer - Brittany
SH
Lynden, WA
Posted: 03/21/12 08:11am Link  |  Print  |  Notify Moderator
okiejoe wrote:
kinda of sounds like a turbo problem.
That would be my novice guess also!
PS I don't get anywhere near 16mpg towing with our 07 LMM Duramax. And I drive like an old man! (which I am).
2011 Heartland Big Country 3450TS
2007.5 Chev LMM Duramax/Allison
2010 FLHTC Electra Glide Classic Red Hot Sunglo
Heartland Owners Club - Washington Chapter Leaders
wborst
North Carolina
Posted: 03/21/12 09:52am Link  |  Print  |  Notify Moderator
I'm thinking transmission cooler line break. He said the engine reved but no power???
Brenda, Bill and our little dog Madison
2007 Pilgram Legends 31RE3SLF-5
2005 Dodge 2500 Quad Cab 4x4 w/Cummins Turbo Diesel
45Ricochet
North Idaho
Posted: 03/21/12 11:04am Link  |  Print  |  Notify Moderator
Good luck OP. As 6.4's are starting to get some higher mileage now the problems are starting to add up. If its fixed on Fords dime you might start thinking about a extended warrany or a replacement. You can certainly learn a bunch on the Ford forums. There is so many potential problems I wouldn't guess myself. This member pretty much sums them up.
Link
Good luck
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Suzanne and Brad
Oregon
Posted: 03/21/12 11:53am Link  |  Print  |  Notify Moderator
We TOTALLY get what you're thinking - have been there (recently). Planned to hit the road to fulltime for a years - a month before leaving found out that I'd need surgery (major, but not life threatening). Then once that was taken care of, in the mail arrived my summons for jury duty for the following month. Got that taken care of, then within a couple weeks while driving in Nevada, our roof blew off. We were having the same thoughts & conversations as you are right now. We even posted a similar thread in RV.net forums. Trust us - it is not an omen/karma and it means nothing. It will pass and you will love your rig & traveling. Hang in there!!!
Happy Travels!
Suzanne & Brad
ib516
Up here!
Posted: 03/21/12 02:07pm Link  |  Print  |  Notify Moderator
Well OP...what happened to your truck? Any diagnosis yet?
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Butch50
Bentonville, AR
Posted: 03/21/12 02:29pm Link  |  Print  |  Notify Moderator
I'm not sure on the 6.4 but on the 6.0 the 4.30 option on a dually was the Tow Boss option. It increased the GCWR capacity from the standard 23K to 26K. My 2006 F550 6.0 had 4.88 rear, The F450 Cab Chasis was avaiable in either 4.30 or 4.88 with the diesel,the F450 pickups have 4.30.
* This post was edited 03/21/12 07:58pm by an administrator/moderator *
Butch
2011 F350 KR 4X4 CC LB SRW
2012 Northern Lite 10 2 CDSE
2008 Custom Weld 17' Boat
2010 Can-Am 650XT Outlander Max
2012 Harley Tri Glide
autorot8
N. CA
Posted: 03/21/12 02:45pm Link  |  Print  |  Notify Moderator
I had something similar, engine would rev, no power, a little oil drip. Ended up just being the turbo air intake hose blew off. I guess this its somewhat common.
F-350 towing a Prime Time Lacrosse 296BHS
"Overstating the Obvious rarely helps the Oblivious!"
