RV.Net Open Roads Forum: Tech Issues: Thoughts on Champion 1000 Watt Inverter Generator
 > Thoughts on Champion 1000 Watt Inverter Generator
cruz-in
Southern Maryland
Posted: 03/20/12 06:51pm Link  |  Print  |  Notify Moderator
Hi All,
Just need a small light weight 1000 watt generator to recharge batteries every once in a while on the 5th wheel. Read lots of good stuff on the Champion 2000 watt inverter generator. Anyone have any thoughts or experience with the 1000 watt model? Here is a link to the data sheet:
mobilefleet
on the road
Posted: 03/20/12 07:13pm Link  |  Print  |  Notify Moderator
I have a champion 3500 watt generator and paid less than 300 for it, and it has seen lots of use for the past 5 years. Yes it's made in China and has the knock-off Honda clone engine but it has done just fine. If you will only use it occasionally it would be good, but if you were a full-timer I'd spend the bucks for honda or yamaha
ScottG
Bothell Wa.
Posted: 03/20/12 08:52pm Link  |  Print  |  Notify Moderator
A 1KW genny isn't big enough to run some larger battery chargers.
Scott, Grace and Wesly
H0NDA eu2000i
Wayne Dohnal
Bend, OR.
Posted: 03/20/12 09:19pm Link  |  Print  |  Notify Moderator
The eu1000i maxes out between 40 and 45 amps on a converter without power factor correction. Some eu1000i users with PD converters and a really low battery force the converter out of boost mode for a while for the initial high-current part of the charging.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
smkettner
Posted: 03/20/12 09:36pm Link  |  Print  |  Notify Moderator
I want one. Kipor runs fine though.
$418 on amazon. Champion is not giving them away.
675 watts solar
fatmanobx
Russellville, Ar. Home Base
Posted: 03/20/12 09:14pm Link  |  Print  |  Notify Moderator
We have a 3500/4000 that we use at deer camp and it runs darn near the whole week at a time. It has never failed to start and to handle the loads we throwed at it.. good for the money..
2003 Four Winds Infinity 37'
2011 Lance 855
3.5# Minpin named Darcy
Ford F250 Super Duty
mlts22
Austin, Texas
Posted: 03/20/12 10:15pm Link  |  Print  |  Notify Moderator
There isn't much difference in price and size between the 1000 watt model and the 2000 watt model. Yes, the 1000 watt is OK for charging a battery, but why not pay slightly more and get a 2000 watt model which can do a lot more? If you ever want to run two generators in tandem for boondocking, you can get another CPE 2000 watt model.
There are only two times I would recommend a 1000 watt generator:
1: If you never, and I mean never, boondock or dry camp. Then, the 1000 watt generator is good to have just in case of emergency.
2: If you have a built in genset in your rig such as a Generac or Onan, and need something small for battery charging, and in some cases getting enough charge in the batteries so the main generator can start.
In either case, I'd look to find a physically smaller generator than the CPE model. Powerhouse and red/blue both have ones that are very compact, and can easily go inside a storage compartment.
mike-uswest
Central Point, OR, USA
Posted: 03/21/12 09:30am Link  |  Print  |  Notify Moderator
I use a Yamaha 1000 for when the sun doesn't have a chance against heavy clouds or there is a wad of snow on the solar, and it works fine to keep enough power in the batteries for the TV. We don't ever worry about the air or microwave. The 1000 is very light and small, so I can get it into my storage easily.
Mike
2003 Dodge 2500 CTD, 4X4,
1994 Alpenlite 26'fifth wheel
See picture in profile.
bradyk
Calgary, Alberta
Posted: 03/21/12 09:41am Link  |  Print  |  Notify Moderator
Just a reminder that the 1000w Champ is a rebadged Kipor. I considered it before as well for a small genny as I don't use the 4K all the time and decided on the 2000w instead. It is only a couple of pounds diffeerence and gives a little more flexibility to what I can run if I need to.
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Champion 4000W Generator
Champion 2000W Generator
Ken & Sandra
Yugi Dog, Jet Dog
16 Foot Renken Fishing boat
DSchmidt_2000
Ventura
Posted: 03/21/12 04:20pm Link  |  Print  |  Notify Moderator
Not anymore. The one listed by the OP is not the Kipor rebadged one.
I was hoping to pick up one of the CPE Kipor 1000W models but they're not making it anymore.
