RV.Net Open Roads Forum: Class B - Camping Van Conversions: Should I buy?
Escargot
California
Posted: 03/22/12 07:47am Link  |  Print  |  Notify Moderator
Mar-d-mar wrote:
Escargot, That's the unit. What's your opinion on the total life? Could I expect 250000, 300,000?
I second what 1775 suggested. Take it to a mechanic and have it checked out.
I will tell you that I had 210,000 miles on original engine of my '87 Westy (VW Westfalia) and it was still going strong when I sold it.
Good luck.
New to me as of May 2013 (WOOT!!):
2006 Pleasure Way Plateau TS, MBE Sprinter
Mar-d-mar
Blue Springs, MO
Posted: 03/22/12 10:05am Link  |  Print  |  Notify Moderator
Thanks everybody. I have scheduled the van to be inspected tomorrow. They are going to "Drive, Scan and Rack" it whatever that means. Hopefully there will be enough information for me to make a good decision.
When an old engine dies, does it just quit in the middle of the road, or will I get some notice if I take it in for regular checkups?
Horizon170
Jefferson, GA
Posted: 03/22/12 10:30am Link  |  Print  |  Notify Moderator
No set rule on that. It could stop all at once (Rarely) or it could just gradually degrade by losing compression and being hard to start.
Ask the same question to the guys that are checking it out.
Gook Luck with your decision.
Marvin
Handbasket
Asheville, NC
Posted: 03/22/12 12:56pm Link  |  Print  |  Notify Moderator
'Drive, scan, and rack' means that they'll drive it to listen an d feel for unusual noises or behavior, scan the engine computer for malfunction codes, and put it on the lift (rack) for visual inspection. Compression and leak-down test would involve more labor $ and take longer, but should give you some indication of the engine's internal condition.
Usually a dying engine will indicate its poor condition by using oil, smoking, loss of power, hard starting, odd noises, etc. Occasionally a timing chain will break, shutting it down, or a connecting rod will poke thru the side of the block. It's more likely that you'll get tired of fixing little stuff that goes wrong, and their cost. Transmission failures seem to occur with less or no warning.
Jim, "Art is anything you can get away with."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Mar-d-mar
Blue Springs, MO
Posted: 03/22/12 02:19pm Link  |  Print  |  Notify Moderator
Does a transmission failure completely stop you or do you just get limited use?
Handbasket
Asheville, NC
Posted: 03/22/12 02:30pm Link  |  Print  |  Notify Moderator
Depends on the manner of failure, and there are a number of them. You'll definitely want an emergency roadside service plan (similar to AAA, but for RV's, which AAA isn't in some areas).
My 1st B (a Roadtrek 190 on a '99 Dodge) was bought with a failed transmission. It moved just enough to get it onto the trailer. I don't know how much warning it gave the PO. Total repair cost was about $3600 for a nation-wide warranted Jasper rebuild and a new radiator (old cooler was plugged with debris from tranny).
Jim, "I like the dead... they're so uncritical."
MAU MAU
New Hampshire and Maine
Posted: 03/22/12 03:04pm Link  |  Print  |  Notify Moderator
Remember, $8000 maximum!
Roadtrek 170 Popular
Mar-d-mar
Blue Springs, MO
Posted: 03/22/12 08:20pm Link  |  Print  |  Notify Moderator
Mau Mau, They listed it for 12995, and said 10995 was their lowest. I will shoot for 8000, but somehow I think they'll turn me down. Should I wait them out? Call back in a couple months to see if it sold?
goreds2
OH H ..... EYE OH !
Posted: 03/23/12 04:23am Link  |  Print  |  Notify Moderator
You should offer 8000 then walk away if not accepted. Make sure you leave them your phone number and tell them you will look at other ones which you should do anyway. Best wishes,
Have you tried craigslist?
Click here and choose city near you.
See Picture In My Profile
1990 Dodge XPLORER RV Van- Purchased 10/15/10
Chick Magnet !
* Sportsman GEN154 2000 Watt 80cc Portable Generator *
XM Satellite Radio since 12/25/2004
Sold my Class C 1976 Dodge TEC Motor Home 9/25/10
retraite
Wanderin' about
Posted: 03/23/12 06:17am Link  |  Print  |  Notify Moderator
Another technique is to lay your check on the sales reps desk - made out to the seller, dated, amount filled on, but unsigned. And let it linger there a bit, but with your pen in your hand "wanting" to sign that check.
Some sales reps just can't pass up the money.
Cheers.
