RV.Net Open Roads Forum: Truck Campers: Camper for 1/2 ton truck?
 > Camper for 1/2 ton truck?
billtex
RI
Posted: 03/22/12 12:00pm Link  |  Print  |  Notify Moderator
I am no fan of 1/2 tons by any means, but if you are sensible, it can be done, and is done all the time;1/2 ton success story
Also check out Expo Forum...many of these Guys want to run small/light and they have some pretty slick set-ups.
We prefer the creature comforts of a hard side, and we use our TC for skiing in the winter. There is no way I would haul our's on a 1/2 ton.
But let's not dismiss 1/2 tons entirely. There are many options...and that's what makes TC's so awesome...
Rock on, Bill
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
enine
OH
Posted: 03/22/12 02:56pm Link  |  Print  |  Notify Moderator
The first time I ever towed a little trailer with mine it had a lot of sway, after changing the P tired to D rated tires most of that was gone. I have pretty stiff rear springs, you can feel every bump, so tires and spring options can make a difference. The previous owner had it on one of those new Toyotas and even with air bags it sunk the back end pretty far, he was amazed when mine barely sunk at all, so differences in models of 1500's can make a huge difference which may account for some of the variances in answers.
Mine hauls, handles, brakes just fine, you can see the weight has barely sunk it, i've seen trucks leaving lowes and home depot with the rear sagging lower than that from a load of mulch.
I've went up and down some pretty steep WV roads.
Anyone knows this this stretch of I70 just before Cabela drive http://maps.google.com/maps?q=Cabela+Drive&hl=en&ll=40.061913,-80.577765&spn=0.026539,0.055189&sll=40.051928,-80.587292&sspn=0.026543,0.087891&hnear=Cabela+Dr,+Triadelphia,+Ohio,+West+Virginia+26059&t=m&z=14
I'm still passing minivans and subarus who have dropped below the speed limit.
We made the mistake of buying a Plymouth Vorager (dodge minivan) and coming down the route 7 mountain between Terra Alta WV and Kingwood WV would overheat the brakes, I had to stand both feet on the pedal every trip when we finally got into Kingwood and I had to buy new pads and rotors every fall after making a few summer trips, the truck and camper handles it fine. I've had many panic stops with the camper, people see a truck with camper or RV and assume its going to slow them down so rather than wait and get behind it they will pull out right in front (ask any OTR truck driver) so we've had to panic stop to keep from rear ending a couple people who have done that before.
* This post was edited 03/22/12 06:32pm by an administrator/moderator *
brianjw
Here and There
Posted: 03/24/12 12:09pm Link  |  Print  |  Notify Moderator
Lots of generalizations here about half tons. Truth is, they are all different. I wouldn't want to haul around much camper weight on an early 2000's half ton, and many current half tons. But plenty of recent half tons are very capable of hauling a small camper.
My truck did require air bags with a 1400-1500lb camper to sit right, but I also have a 2" leveling kit. I already had bilstein shocks and d-rated 35" tires, a 5.4l engine with a few small mods, 4.56 gears etc. Power and braking are no problem whatsoever, even with 35s. The brakes are as big as you can fit inside a 17" wheel. I hauled the camper over 8700ft passes with a 6x10 cargo trailer in tow without brakes, absolutely no problem up or down the mountains. Handling was great with mentioned mods.
Overweight? Yeah, a little. But it would have been within gvwr if I had the same truck with the hd payload package, I have the heaviest f150 setup with the lower payload (softer leaf springs).
I just sold the camper because I have other projects to work on, but fully intend to have a smaller pop-up built eventually that will stay on the truck full time. My truck has several years of hauling a camper shell loaded with tools, and thousands of miles with the camper and trailer and it sure isnt falling apart, and never scared me once.
The new owner of the camper drives a Chevy 1500hd. We loaded the camper on his truck (completely stock) and the back sunk a couple inches, but is nice and level front to back. Now if it has a 5.3 it is probably miserably underpowered but again, there are plenty of good options.
If you want something to fall into the weight category you're looking at, some of the lightest hard side campers might be a travel lite, they have a few models that work great on a good half ton. For pop-ups, there are many options. Four wheel, ATC, Phoenix, etc. It is true that you will need to pack light. If you tend to lug around tons of extra junk a half ton isnt going to work well with any camper.
2006 F150 SuperCrew FX4 - Bilsteins, Hellwig sway bar, Firestone air bags, BFG KM2s, 4.56 gears, F&R lockers, Torklifts w/ Fastguns
2011 Travel Lite 700
billtex
RI
Posted: 03/24/12 07:02pm Link  |  Print  |  Notify Moderator
brianjw wrote:
a 5.4l engine with a few small mods, 4.56 gears etc. Power and braking are no problem whatsoever, even with 35s. ... Now if it has a 5.3 it is probably miserably underpowered... I just sold the camper...
ronanddi
las vegas
Posted: 03/24/12 10:22pm Link  |  Print  |  Notify Moderator
After reading the responses I had my truck weighed. Bad news, the payload was not even close to what was listed.
GVWR: 6400
Weighed at local transfer station (with driver and 1 passenger, full tank of fuel: 5600
This leaves me a payload of 800 lbs, right? This won't work for me, I can't believe the payload could be so little. I guess I'll be shopping for a 1 ton.
Thanks for all the input.
Joners
Idaho Falls, Idaho
Posted: 03/23/12 12:13am Link  |  Print  |  Notify Moderator
Like "we" used to say back in the 60s..."If it feels good, do it". Check my signature.
Cap'n Bob
1996 Chevy K1500 4X4 Short Box, 5.7L Vortec, E rated tires, Lance Model 820 with Cabover Struts, Firestone Ride-Rite Air Bags, KYB MonoMax Shocks, Torklift Stable Loads, Happijac Truck Camper Tiedowns and Turnbuckles, Honda Eu2000i Inverter/Generator.
Padlin
W. Ma.
Posted: 03/25/12 05:32am Link  |  Print  |  Notify Moderator
800 lbs, what is your truck, you never said?
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
ronanddi
las vegas
Posted: 03/25/12 06:04pm Link  |  Print  |  Notify Moderator
2000 Dodge 1500, extended cab, long bed, 5.9L Gas
elkhornsun
Monterey
Posted: 03/29/12 06:48pm Link  |  Print  |  Notify Moderator
With your current truck an "off-road" popup camper is your best bet. They are made to be light and constructed in a very different manner than conventional truck campers. You will end up with a porta potty and some other limitations but your truck will be able to handle the load.
Not mentioned but the tires are usually the limiting factor and should be checked for their load rating and compare that to the weight on the rear axle of the truck with the camper in the bed.
Items like water heaters, hold tanks, shower and flush toilet, 3-way fridge, and the like are what add the weight but there are alternatives if you check the websites devoted to off road campers and travel.
