RV.Net Open Roads Forum: '03 E450 presure hose beside transmission dipstcik
 > '03 E450 presure hose beside transmission dipstcik
millerwd
Kittitas
Posted: 03/21/12 02:34pm Link  |  Print  |  Notify Moderator
There is a hose attached to my the transmission dipstick. It has a green plastic cap the unscrews exposing a pressure valve similar to a valve stem.
What's it for?
Thank you, Bill
"...the man who really counts in the world is the doer, not the mere critic-the man who actually does the work, even if roughly and imperfectly, not the man who only talks or writes about how it ought to be done." T.R.(1891)
tatest
Oklahoma Green Country
Posted: 03/21/12 05:13pm Link  |  Print  |  Notify Moderator
A valve like that under the hood is usually for servicing the air conditioning, but I would not expect it to be a hose, they usually teed off metal tubing.
Maybe you have supplemental air springs on the front, and the installer brought out connections so that you can check pressure and fill without crawling under the front end? In that case, you might look for another hose on the other side of the engine.
Tom Test
Itasca Spirit 29B
millerwd
Kittitas
Posted: 03/22/12 07:55am Link  |  Print  |  Notify Moderator
j-d Copy that.
Thank you, Bill.
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 03/21/12 05:49pm Link  |  Print  |  Notify Moderator
Evaporative Emission Test Port ?
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
j-d
Sunny Florida USA
Posted: 03/21/12 05:51pm Link  |  Print  |  Notify Moderator
Fuel System Pressure Test/Bleed Point! Please leave it alone unless you're servicing the Fuel Injection System!
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
