RV.Net Open Roads Forum: Travel Trailers: Brakes locking up on TT
 > Brakes locking up on TT
opnspaces
San Diego Ca
Posted: 03/23/12 12:02am Link  |  Print  |  Notify Moderator
Yep, the springs keep the brakes from self applying and also pull the shoes away from the drums when you lift your foot. So a loose spring could allow the shoe to wedge out against the drum and lock up the wheel.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Tazymae
Kentucky
Posted: 03/23/12 06:35am Link  |  Print  |  Notify Moderator
Wow, make sense now!!!!! Thank you for explaning it to me in idiot terms I just know we will be ok on our first trip to FL in our TT because there will be people like you all there to help........
Thank you
WHS
Waitsburg, Wa.
Posted: 03/26/12 11:29am Link  |  Print  |  Notify Moderator
Sounds like technician error. Either it was loose and came off when the tech was inspecting/adjusting brakes or he knocked it loose. Either way, sounds like the tech did not double check his work when done. Should be fine now.
Good luck and have a great trip!
skip
05' Layton Lite 170LT Cascade edition
06' Chevy Silverado K1500
We-No-Nah Rendevous, a Ljutic, a Remington, a Hard Rock Pro, a Polaris 550XP & Raleigh the Hunter
Tazymae
Kentucky
Posted: 03/23/12 07:53am Link  |  Print  |  Notify Moderator
Now that my excitement at the issue being resolved, reality has sunk in.....what would make the spring come loose and I wonder if is apt to come off or get loose again while on the road
opnspaces
San Diego Ca
Posted: 03/23/12 10:11am Link  |  Print  |  Notify Moderator
I've never seen a spring pop loose on it's own. It's possible that the mechanic accidentally knocked it loose inspecting or adjusting the brakes, but there's just no way to tell now.
Assuming he made sure the spring was properly seated I doubt you'll have any more problems with it.
