RV.Net Open Roads Forum: Tech Issues: Can you manually crank a slide?
 > Can you manually crank a slide?
judelaurenzo25g
Downey, CA
Posted: 03/21/12 03:31pm Link  |  Print  |  Notify Moderator
We just purchased a 2010 Fleetwood Jamboree 25G and I am new to having a slide. I was wondering if ever the slide should fail is there a way to manually crank the slide back in? I believe its an electric slide if that even matters.
A ship in harbour is safe, but that is not what ships are built for.
JLTN_James
Colorado
Posted: 03/21/12 03:37pm Link  |  Print  |  Notify Moderator
From my limited experince with slides on my father's 5'er, there is a way to manually operate the hydraulic pump with either a drill or hand crank. My father's is in the basement area and he needs to remove a small panel to access the pump.
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, Dog & Camping Kitty
ADAD437
New Albany,Ind. USA
Posted: 03/21/12 03:43pm Link  |  Print  |  Notify Moderator
Mine came with a crank and has a hole in the slide at the bottom, you just stick the crank in and have someone hold the slide button in manual and crank away. The bedroom slide you raise the bed hold the button in manual and turn the shaft attached to the motor. It should be in your owners manual.
James,Gail & Pancho
2005 georgie boy Pursuit
judelaurenzo25g
Downey, CA
Posted: 03/21/12 03:48pm Link  |  Print  |  Notify Moderator
I'll have to keep my eyes peeled see if I can find the actuator/motor
downtheroad
Pacific Northwest
Posted: 03/21/12 03:49pm Link  |  Print  |  Notify Moderator
Most if not all slide mechanisms can be operated manually....usually with a crank or wrench on the motor.
Here is the Lippert Manual that details how...(scroll to pg. 6)
Slide Manual CLICK
We have a port in the skirt that I stick a crank through...very easy.
Here is the rear slide port.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
judelaurenzo25g
Downey, CA
Posted: 03/21/12 04:00pm Link  |  Print  |  Notify Moderator
Thanks again!
skipnchar
Topeka or somewhere else
Posted: 03/21/12 04:56pm Link  |  Print  |  Notify Moderator
I believe that MOST slide rooms have a means of operating them manually but not all manufacturers furnish a handle for the purpose. Fortunately mine came with both the means and the crank because the motor quite about a week before we returned from Alaska and had to hand crank twice a day for that week. 200 revolutions from full in to full extended and 200 more to get it back in. Fortunately it turns very easily. Mine is a 44" deep slide room but smaller ones would be much easier to hand operate.
Forest River puts the crank connection on the DOOR side of the trailer between the axles but inside the fender well.
michelb
Ottawa, ON, Canada
Posted: 03/22/12 04:38am Link  |  Print  |  Notify Moderator
It really depends on the make of the slide mechanism. Some have a manual method, some don't. Our 98 Pace Arrow does not - the front slide can be moved manually relatively easily but still requires disconnecting the hydraulic arm and fastening it somewhere out of the way, the rear slide is nearly impossible to move manually.
