I have 165k miles on my 6.0 psd with basically a EGR valve replacement and/or cleaning every 80k miles and that's about it. Best truck I've owned to date.
Alot of the EMS truck riggers caused alot of the early 6.0 problems by simply using the incorrect antifreeze and wire harnesses that were routed incorrectly that developed chafed wires causing many of these early problems. It didn't help that Ford's techs weren't trained properly to rectify these problems as well.
if it hasnt had a ton of work it will need a ton of work. head bolt, injector, turbo, egr cooler problems on all of them. used to have a constant stream of them to work on. was visiting a friend the other day and three years later there still is.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
