I adress that to the people who change the carpet with laminate.Do you have any problem with the slide out when it come in?The laminate is 10 mm thick.
edited 04/06/12 06:34pm by buc1980 *
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
We used 10mm thick laminate flooring in our 36XTRM5 Carriage Carri-Lite 5er and have not had a problem. We used the flooring in link below from Home Depot and like it and its workout well for us. We also removed the carpet in the slides and replaced it with the same flooring.
I want to give an update to the project.Yesterday I and my DW start to install the new floor.After 12 hours of work we have a little more at the entrance to finish.I can tell you that after 12 hours I am dead tired.Next weekend will finish and start the bedroom.
buc1980 wrote: I want to give an update to the project.Yesterday I and my DW start to install the new floor.After 12 hours of work we have a little more at the entrance to finish.I can tell you that after 12 hours I am dead tired.Next weekend will finish and start the bedroom.
Be sure to post some pics! BTW, what brand of laminate did you end up going with?
The big slide out have carpet .The carpet cover the crack of the slide out.I can't install wood over there because the edge have steel which is cover by carpet and is a little uneven.Anyhow tomorrow I will finish the floor completely.I use Home Legend brand.The slide out slide with no problem on the top of the floor.After I finish tomorrow I will take some picture.
I post the picture at the beginning of the topic suppose to be a update at the end of the topic.Well anyhow if anybody want to look at them you welcome.
