RV.Net Open Roads Forum: Laminate floor in a FW
buc1980
houston tx
Posted: 03/21/12 06:54pm Link  |  Print  |  Notify Moderator
I adress that to the people who change the carpet with laminate.Do you have any problem with the slide out when it come in?The laminate is 10 mm thick.
* This post was edited 04/06/12 06:34pm by buc1980 *
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
ronfisherman
SE Michigan
Posted: 03/22/12 04:43am Link  |  Print  |  Notify Moderator
10mm is over 3/8". Could be a little high. That is one of the reasons for using Allure flooring. It is 3/16" thick.
Kodiak Chassis Class C Forum
dgood
Arkansas
Posted: 04/05/12 02:04am Link  |  Print  |  Notify Moderator
On the slideout is it straight or have a slight curve on the edge?
Ron3rd
Upland, CA USA
Posted: 04/05/12 06:39am Link  |  Print  |  Notify Moderator
buc1980 wrote:
I want to give an update to the project.Yesterday I and my DW start to install the new floor.After 12 hours of work we have a little more at the entrance to finish.I can tell you that after 12 hours I am dead tired.Next weekend will finish and start the bedroom.
Be sure to post some pics! BTW, what brand of laminate did you end up going with?
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
chiefneon
Livingston, TX
Posted: 03/22/12 10:42am Link  |  Print  |  Notify Moderator
Howdy!
We used 10mm thick laminate flooring in our 36XTRM5 Carriage Carri-Lite 5er and have not had a problem. We used the flooring in link below from Home Depot and like it and its workout well for us. We also removed the carpet in the slides and replaced it with the same flooring.
DuPont Tuscan Stone Terra 10mm thick
"Happy Trails"
chiefneon
buc1980
houston tx
Posted: 03/25/12 08:15am Link  |  Print  |  Notify Moderator
westend
all over
Posted: 04/07/12 05:36am Link  |  Print  |  Notify Moderator
Nice work! That is a good looking floor, you should be very proud of the result.
Now you'll have to take off your sandals when you walk in, though.
'03 F-250 4x4 CC
ronfisherman
SE Michigan
Posted: 04/07/12 05:41am Link  |  Print  |  Notify Moderator
Nice job.
buc1980
houston tx
Posted: 04/06/12 06:44pm Link  |  Print  |  Notify Moderator
I post the picture at the beginning of the topic suppose to be a update at the end of the topic.Well anyhow if anybody want to look at them you welcome.
buc1980
houston tx
Posted: 04/05/12 07:44pm Link  |  Print  |  Notify Moderator
The big slide out have carpet .The carpet cover the crack of the slide out.I can't install wood over there because the edge have steel which is cover by carpet and is a little uneven.Anyhow tomorrow I will finish the floor completely.I use Home Legend brand.The slide out slide with no problem on the top of the floor.After I finish tomorrow I will take some picture.
