RV.Net Open Roads Forum: Winegard CarryOut Mounted on Roof - (PICS)
 > Winegard CarryOut Mounted on Roof - (PICS)
dan-nickie
Posted: 03/21/12 08:46pm Link  |  Print  |  Notify Moderator
I always thought my Carry Out dish antenna took up too much valuable storage area. And at many campgrounds/RV Parks I would put it on top of the MH after we set up anyway. So I decided to mount it on top where it would ride, but still be able to take it down to the ground if trees were an issue. So I made up a mount for it.
I bought a Tripod from CW and did not use the legs. I made short brackets to be able to mount the tripod base to the roof, therefore I can easily take the clips out and remove the dish in a jiffy.
First I made some short brackets using items from the local hardware store.
Here is the Tripod Base attached to the short brackets.
This is a close up of the base clipped to the brackets.
And the setup almost complete.
Of course you need to dicor seal all of the screw and bracket attachments at the roof also, but I didn't show that.
And I need to run my cables to the Sat Receiver still. My AV cabinet is just to the right of the dish, so I will be drilling thorugh the roof over near the edge to run the cables down.
* This post was edited 03/21/12 08:52pm by dan-nickie *
Dan and Nickie
2014 Forest River Berkshire 390RB
Old-Biscuit
Verde Valley
Posted: 03/21/12 09:22pm Link  |  Print  |  Notify Moderator
More than one way to mount a dish........
Questions?
Why does it look like bare wood under the bracket thru that center hole?
What's your new height limit now?
dan-nickie
Posted: 03/21/12 09:40pm Link  |  Print  |  Notify Moderator
That is actually putty tape under the brackets.
I have not measured yet, but it should not be an issue. It is just a little higher than the AC unit and the prior height was 10' 9" I think. Maybe it was 10' 4" I can't recall.
* This post was edited 03/22/12 07:27am by dan-nickie *
82corvette
Southeast Nebraska
Posted: 03/22/12 11:51am Link  |  Print  |  Notify Moderator
Nice job!
DD716TED
Washington State
Posted: 03/22/12 09:22pm Link  |  Print  |  Notify Moderator
Is it OK to put putty tape (butyl tape) on rubber roofing material? I like the design but have been told to be careful what I put in contact with EDPM roofing material? Are the brackets stainless?
dan-nickie
Posted: 03/23/12 01:14am Link  |  Print  |  Notify Moderator
I couldn't officially anser about the tape on rubber.
The brackets are galvanized. Typically used for projects like outside wooden structures like patio covers, etc.
