RV.Net Open Roads Forum: Tech Issues: CLR in hot water heater
 > CLR in hot water heater
Fulltimers
Anywhere, USA
Posted: 03/21/12 09:38pm Link  |  Print  |  Notify Moderator
Why shouldn’t I use CLR to clean the white crud in my hot water tank?
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
Old-Biscuit
Verde Valley
Posted: 03/21/12 09:58pm Link  |  Print  |  Notify Moderator
Can you safely drink CLR?
I know its Hot Water.....but it's tied to the plumbing system and if it isn't safe for human consumption I don't want to use it.
I use white vinegar instead......
Jerrybo66
AZ
Posted: 03/21/12 10:00pm Link  |  Print  |  Notify Moderator
Hey, if you don't mind if your hair falls out, your teeth turn black and you develope a facial twitch, then go for it. If you then can still see to type let us know how it turned out. [emoticon] [emoticon]
Sorry, maybe it was the wine but I couldn't resist. Truthfully, I have no idea..[emoticon] Maybe it will work? I just wouldn't try it...
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
old guy
Oregon (pronounced Or e gun)
Posted: 03/21/12 10:27pm Link  |  Print  |  Notify Moderator
you should just buy a clean out wand and hook up a garden hose and spray it out. don't know how you can get enough vinegar in the tank.
buzzard616
Medicine Hat, Ab, Canada
Posted: 03/21/12 10:56pm Link  |  Print  |  Notify Moderator
They advertise the stuff as safe for coffee makers so it can't be that bad. Make sure you rinse it thoroughly afterwards because the stuff does stink and will only be worse if you heat it up.
Stu
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
sdianel -acct closed
Tampa, FL
Posted: 03/22/12 02:02am Link  |  Print  |  Notify Moderator
from the Jelmar website: Can I use CLR on my water heater?
No, Jelmar DOES NOT RECOMMEND the use of CLR on a water heater; however, there is a web site that does. Again, JELMAR DOES NOT RECOMMEND THE USE OF CLR IN A WATER HEATER. The reasons Jelmar does not recommend CLR to clean a water heater are: 1) the heat is not compatible with CLR; 2) the water heater cannot be promptly and thoroughly rinsed with cold, clean water; 3) the water heater might have internal metals that are not compatible with CLR.
4*phun*2
Canada
Posted: 03/22/12 05:54am Link  |  Print  |  Notify Moderator
How are you going to get it into the HW heater? How much are you going to put in?
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
JC2
Mo/Texas
Posted: 03/22/12 06:33am Link  |  Print  |  Notify Moderator
X2.[emoticon]
I put 1gal of generic white vinegar per 15gal of tank capacity in my fresh water tank. I then open each faucet inside and the outside shower also until I smell vingar and let sit for 4hrs. This concentration mix will go through all your lines/faucets/water heater and dissolve the calcium/crud. Drain them refill with fresh water, run through lines and do a final drain.
* This post was edited 03/22/12 06:44am by JC2 *
2004 Newmar DSDP 4015,Cummins ISL 370hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
Old-Biscuit
Verde Valley
Posted: 03/22/12 09:21am Link  |  Print  |  Notify Moderator
X2.[emoticon]
Or if just want to treat the water heater tank......drain it, remove relief valve and pour gallon of vinegar in with funnel. Replace relief valve & fill tank then let sit for 4 hrs. Drain and flush. I do this after leaving S/W US due to hard water.
I think next time I'll try your method and do the whole system.
Thanks [emoticon]
ryanallie1
Fall River Mills, Calif
Posted: 03/23/12 09:22am Link  |  Print  |  Notify Moderator
Hi All.
We think this is a pretty simple question to answer. And just using "Good Old Fashioned Common Sense, says:
If you "CAN NOT" drink it, then "DO NOT" put it into your Water System, Period.
Best of Luck to you. Good Luck. Happy Travels. Dan & Jill
1998-34 ft Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
