RV.Net Open Roads Forum: Best way to clean up oxidation from exterior walls
 > Best way to clean up oxidation from exterior walls
opastrains
Richmond, MI
Posted: 03/22/12 07:30am Link  |  Print  |  Notify Moderator
Purchased a used fiver which had not been waxed for several years. What is best way to remove oxidation from walls before applying wax. Started waxing without doing anything about oxidation, and get lots of streaks. :-(
Any advice?
bailer6334
Prescott, AZ
Posted: 03/22/12 07:36am Link  |  Print  |  Notify Moderator
One recommendation is to use Meguiars RV Wax Kit.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
Emptypockets
North Central KS
Posted: 03/22/12 07:40am Link  |  Print  |  Notify Moderator
X2 It is a 3 step job
Crazy Ray
Monroe,La
Posted: 03/22/12 08:27am Link  |  Print  |  Notify Moderator
Go to Wally World in Boat/fishing section and get 3M fiberglass restore. Worked great for me. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
MichDoc
Michigan
Posted: 03/22/12 08:37am Link  |  Print  |  Notify Moderator
Any marine or RV store will have oxidation remover or color restorer. All should work, but start with the least aggressive first. Don't use rubbing compound.
Road Phantom
pa
Posted: 03/22/12 08:54am Link  |  Print  |  Notify Moderator
I used a Star Bright product. www.starbright.com. It works great on heavily oxidized surfaces. Still, it takes a lot of elbow grease and plenty of rags. I used it on a 37 ft 5th I used to have and it took two days work to finish. I followed it up with a good wax and the trailer went from dull with streaks, to shiny and brand new.
phillyg
Front Royal, VA
Posted: 03/22/12 08:55am Link  |  Print  |  Notify Moderator
Or, o a search here for "Red Max Pro" or "RMP" and you can read about all the prep work that has to be done, and how to do it, before putting on the RMP. It might make you a RMP applier, too.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
gbopp
The Keystone State
Posted: 03/22/12 10:16am Link  |  Print  |  Notify Moderator
x2 on using BKF and Red Max Pro.
Your rig will look like new, and the cost is very low.
sonicsix
Jerry n' Cynthia
Posted: 03/22/12 12:22pm Link  |  Print  |  Notify Moderator
We just cleaned our heavily oxidized Class C with Meguiar's One Step Compound and it did a fantastic job! After we did the cleaning, we put on a coat of Nu Finish paste polish. The camper looks almost like it did new.
AtomicChicken
Central Louisiana
Posted: 03/22/12 01:24pm Link  |  Print  |  Notify Moderator
Star Brite link is actually http://www.starbrite.com/
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
