RV.Net Open Roads Forum: General RVing Issues: 6v versus 12v
 > 6v versus 12v
Page of 6
TWO 4 THE ROAD
AZUSA,CA
Posted: 03/22/12 10:32am Link  |  Print  |  Notify Moderator
I have two 12v Marine batteries hooked up to my 5er and it seems to work pretty good. Talking to different RVers, I keep hearing that 2 6v batteries would be better. They can't seem to tell me just why they would be better, so I thought I'd ask you folks. Since we do a lot of dry camping and sometimes we can't use the generator due to CG rules. I'm looking to increase the life of the batteries.
thanks
07 Forestriver Flagstaff 8528GTSS, 07 Chev,2500hd, D/A, , 2000 Mitsubisi Eclipse. ,DW Kathy,DD Maggie
SWD
Land of Living Skies
Posted: 03/22/12 10:41am Link  |  Print  |  Notify Moderator
When your 12v batteries need replacing, go with 2 6v units. The 6v batteries have more lead, hence a greater charging/storage area and can give you more draw down amps than a 12v unit. Check out this site:clicky
skipnchar
Topeka or somewhere else
Posted: 03/22/12 10:47am Link  |  Print  |  Notify Moderator
Better is a pretty subjective term. the total number of AMP hours provided tell how much POWER a battery bank puts out and in MOST cases the two 6 volts equal more than two 12 volt batteries but that's not always the case. The biggest ADVANTAGE two 6 volt batteries have is the number of charge/discharge cycles they will withstand before giving up. My last set of Trojan T-105s lasted me eight years (would have been longer except they were stolen this spring). Most 12 volt batteries will NOT last that long when used with frequent cycles of 50% discharge. Doesn't mean that 6 volt is BETTER in every circumstance but when used properly they usually last longer.
donn0128
Pronounced Ore-gun
Posted: 03/22/12 11:05am Link  |  Print  |  Notify Moderator
What sort of camping do you do? If you only go full hookup then two 12VDC batteries is more than enough. If you do a lot of boon docking then 6VDC is a better choice. But you also have to remember that 2-6volt batteries is only one 12 volt battery is a large box.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Golden_HVAC
Fulltime, CA, USA
Posted: 03/22/12 11:13am Link  |  Print  |  Notify Moderator
I was not sure they where better or not, but only got about 2-3 years out of a set of 12 volt batteries. The factory 6 volts that came with my Bounder motorhome lasted 9 years, and I gave them to a friend when I was going to start full timing, so I would have a fresh set (the new ones where not more powerful than the old ones).
The second set is now about 6 years old, still going strong.
What are your 12 volt batteries doing for you?
The 6 volt has much more space around the plates for water, they run cooler, have more space under the plates for mineral buildup before the plates short out, not as likely to overheat and warp (causing a short circuit).
The 6 volts tend to last up to 10 years when used in a home, where they are charged daily by a solar or wind system, and discharged each night.
I like them so far, and have no plans on going back to 12 volt batteries, only recommending them when a pair of 6 volt will not work. Such as under the hood battery, a group 31 might fit, giving 125 amp hours capacity, while the group 27 was only around 100 AH. They do make a 185 AH 12 volt battery, I used one in a manlift, however it is 85 pounds, and while nice to keep the manlift stable, most do not care for that much weight. It was a Trojan 5SP battery.
THink of the 6 volt battery as 1/2 of a really heavy battery, like the 8D that is truly a heavy duty battery, in two parts, not one big 120 pound battery.
Fred.
MudChucker
Niverville Manitoba
Posted: 03/22/12 11:51am Link  |  Print  |  Notify Moderator
There are advantages and disadvantages to various voltages.
Given the same total amp-hours here are some observations:
Large two volt cells in series offer the lowest statistical chance of cell failure as only six are in use.
Twelve volt in parallel offer better total amp-hours if the batteries are not totally identical.
Series six volts are limited in amp-hours to the capacity of the worst cell of the six.
Twelve volt offer lower voltage drop for the same "demand" allowing large inverters to run longer before the voltage drops too low.
Here are some further thoughts.
If there is room for 3 batteries then 50% more amp-hours can be had in a 12 volt format.
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
2oldman
Winchester WA
Posted: 03/22/12 12:16pm Link  |  Print  |  Notify Moderator
12v vs 6v batteries
More 12v vs 6
12v vs 6v 2010
Why 2 6?
Anybody had one 6v fail?
12v v 6v 2010
12v vs 6v Feb 2010
SWD
Posted: 03/22/12 12:32pm Link  |  Print  |  Notify Moderator
Like I said in my previous post, check out the site: The 12v side of life.
My experience has been over a 12 years period of time. Operating 4 solar powered stock waterers, using 3 24v pumps and 1 12v. The first set of 12v batteries went south after 2 years, I changed over to 6v units, which now after 10 years, I'm having to start replacing. These batteries are subjected to numerous charge/re-charge cycles and temp changes over a 12 month period.
* This post was edited 03/22/12 12:51pm by SWD *
AO_hitech
SF Bay Area
Posted: 03/22/12 12:51pm Link  |  Print  |  Notify Moderator
The advantages of placing battery cells in series (as is done with 2 6 volt batteries) out weights any advantage of placing cells in parallel (as is done with 2 12 volt batteries).
That is why you never see any devices designed to use battery cells in parallel unless they have to because of a specific voltage requirement.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 03/22/12 02:50pm Link  |  Print  |  Notify Moderator
Without getting technical - not qualified to even try to get technical - but: I've had both. I had little problem with using two 12 volt deep cycles when we boondock and now I have 4 - 6 volt deep cycle batteries. I prefer the 6 volts over the 12's because they seem to give a bit longer cycle life than the 12's did.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
Page of 6
 > 6v versus 12v
