RV.Net Open Roads Forum: Class A Motorhomes: Awning strap has disapeared.
 > Awning strap has disapeared.
Grillmeister
BBQ TOUR USA
Posted: 03/22/12 03:50pm Link  |  Print  |  Notify Moderator
wrvond wrote:
chili's trip wrote:
Thanks guys! I got the arms to release by using both of your techniques then standing in the open door way and grabbing the fabric and pulling until the strap appeared. A passerby used the hook to grab the strap. I am going to attach something to extend the strap so this does not happen again.
If you put a zip-tie through the end of the loop it'll make a more rigid open loop that is easier to hook with the rod and also adds an inch or two to the over all length.
Great idea, since I have a few hundred zip-ties around I don't know why I did not think of it
Thanks for another great suggestion!
Show me the GRILL and STAND BACK!!!!
ArmySFCRet
Moving to Congress, AZ
Posted: 03/22/12 04:13pm Link  |  Print  |  Notify Moderator
Just be aware that zip-ties are subject to UV breakdown. They will get brittle, and will soon break easily. Zip-ties do not last long when exposed to sunlight.
'04 Cross Country 35' w/300 Cummins
'05 Sebring CV on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/TWIN H-POWER
5 lbs of BG the Yorkie
Members of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
wrvond
West Virginia
Posted: 03/22/12 06:36pm Link  |  Print  |  Notify Moderator
Executive wrote:
Just remember, anything attached to the end of that pull strap will beat your paint to death while under way....just sayin.....Dennis
I've never experienced a problem with it. I suppose if it's long enough it could possibly be something to consider...
1988 24' Alumilite XL Class A by Holiday Rambler w/Ford 460
1990 25' 2609IN Innsbruck by Gulf Stream
1996 5.2L Jeep Grand Cherokee Limited 3.73 gears and factory tow package
PaulJ2
Northwest Oregon
Posted: 03/22/12 04:19pm Link  |  Print  |  Notify Moderator
powderman426 wrote:
If you extend it much more than 6", it will flap around and make noise or be a distraction. Just attach the puller hook into the loop when you close it, and it will put enough tension on it that it will roll up straight.
I like this idea. The weight of the pull rod should make it wind up straight every time.
Executive
Posted: 03/22/12 04:56pm Link  |  Print  |  Notify Moderator
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
borntwotravel
Central IN
Posted: 03/22/12 05:22pm Link  |  Print  |  Notify Moderator
We all have a few hundred laying around because every time we need them we can't find them so we buy more. After we have bought them 10 or 15 times they contact each other and migrate to the same spot.
The stop by the dryer and take the socks that are hiding too.
Grillmeister
BBQ TOUR USA
Posted: 03/23/12 08:10am Link  |  Print  |  Notify Moderator
sundancer268 wrote:
Normally the Black Zip Ties will be UV rated and not fail. The uncolored ones will fail sooner than you will like. I no longer buy the plain Zip-Ties and use the remaining plane ones for temporary use.
I had the same experiance, the white ones last about 6 or 7 months in the sun. The black ones last 6 or 7 years.
Grillmeister
BBQ TOUR USA
Posted: 03/22/12 06:45pm Link  |  Print  |  Notify Moderator
Now THAT is funny :
sundancer268
Charlevoix
Posted: 03/22/12 07:05pm Link  |  Print  |  Notify Moderator
U. S. Navy (RETIRED) 1993
1995 Gulf Stream Scenic Cruiser 34' Diesel Pusher Cummins B5.9 12 Valve Engine, Allison MD-3060 6 Speed Transmission.
TOAD: 2005 Ford Focus Automatic Station Wagon
Road Master Sterling All-Terrain
