RV.Net Open Roads Forum: No 110v shore .... gen 110v OK
 > No 110v shore .... gen 110v OK
Fred420
Indiana
Posted: 03/22/12 06:00pm Link  |  Print  |  Notify Moderator
We just brought the coach from the storage place and I hooked up to my shore power and nothing. I have a 220v properly wired that I have been using with no problem. I use a 50/30 adapter as my 220v coach cord is not long enough. The house breaker is OK. I have power all the way to the end of my power cords, checked with a meter, 115v. I checked to see if I had 110v while running the Gen again, and I did. All 110v worked.
We camped 2 weeks ago on shore power with no problems. Last week we went to the state park for the day and we used the Gen for aprox. 1 1/2 hrs with no problems. There was no shore power available.
I do not know if the transfer relay/switch is bad? Is there a fuse hiding somewhere?
Thanks for your input,
Fred
We are suspose to leave Friday night to camp .................
__________________
Dave and Lynn Davis
2 Danes; Palmer and Desi Rae. 280#'s
2006 Monaco LaPalma DP
www.RCCOMBAT.com
No Cuts....No Glory
"Fly it like you stole it"
Certified Baseball Umpire
College, High School, MABL, American Legion, Little League
sch911
Rochester Hills, MI
Posted: 03/22/12 06:10pm Link  |  Print  |  Notify Moderator
Never heard of a 220V RV hookup. Are you sure? Or, do you mean 120V @ 50A?
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
wolfe10
Posted: 03/22/12 06:15pm Link  |  Print  |  Notify Moderator
Yes, a properly wired 50 amp RV outlet could be referred to as 240 VAC, as hot to hot IS 240 VAC.
Good idea to disconnect and ohm meter check the adapters-- they are usually not as well done as the cords.
If, repeat If you are safe working around 120 VAC, with power off, remove the top to the ATS. Plug it back in and check for power and proper wiring at the ATS.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Fred420
Indiana
Posted: 03/22/12 06:20pm Link  |  Print  |  Notify Moderator
You are right .........240v It is wired properly, I have not had any problems up to date. The power at the end of the cord going into the coach reads 112-115v from Neutral to either side terminal, nothing on the bottom terminal to neutral.
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 03/22/12 06:42pm Link  |  Print  |  Notify Moderator
Please do not multiple post
See thread running here.
Thanks
Admin
RV.net
