Dirtclods
Newport Beach
Trouble shooting: http://www.lci1.com/OwnersManuals/Slideout/Electric%20Slideout-Web.pdf
IOWASTROKER
rocky mountians
On our '06 Raptor from Keystone, it happened all of the time. Jumping the CB, they worked fine. Sold it before I replaced them. On our 2010 Cyclone, with two new deep cycle marine 12-volt batteries, I can run my slides in and out numerous times without shore power or gen set....and no two batteries with diesel running from truck. They pull some juice, but not enuf to drain two batteries, that, in your case, are suppose to be OK. Keep us posted )
MadMav
Colorado Springs, CO
I suspect a bad cell in the batteries. Will take a charge, but as soon as a load is on them they will fail. Charge both up and only use one at a time. This should tell you which one is bad.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
Stkx66
Garden Grove
We have a Raptor 2006 3612. Recently our fuel pump quit working. Thompsons in Colton diagnosed the problem in 5 minutes. The fuse was bad, not burnt out, just old. After that before our next trip a light in the front bedroom fizzled and quite working. Story short- I replaced all those 15 amp fuses ( that were good ) in the fuse panel with all brand new ones. The new fuses fixed my light that was broken AND my slide no longer pulsed when opening or closing with no gen. or shore power hooked up- Battery power only. $ 10.00 in new fuses did wonders.
edited 03/28/12 05:28pm by Stkx66 *
nayther
Burbank, CA
Stkx66 wrote: The fuse was bad, not burnt out, just old.
That makes no sense what so ever. Fuses don't "get tired" they melt/open. Like changing the freon in your A/C because its "tired" or rotating/changing the air in your tires.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
dedmiston
Valencia
Could the legs on the fuses be corroded/dirty and making bad contact?
Shave your legs.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
big buford
Buena Park, Ca
Honcho en china
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
