RV.Net Open Roads Forum: Toy Haulers: New member here..question about slide out probs
Search only in Toy Haulers
 > New member here..question about slide out probs
big buford
Buena Park, Ca
Posted: 03/22/12 10:47pm Link  |  Print  |  Notify Moderator
Think next I would check all pos and ground connections to ensure they are clean and tight.
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
fuzionhauler
Alaska
Posted: 03/22/12 10:50pm Link  |  Print  |  Notify Moderator
Everything appears to be tight and clean but I'll double check to make sure.
mpierce
Scranton, ND
Posted: 03/23/12 05:41am Link  |  Print  |  Notify Moderator
Change the CB. They do go bad, and will trip too easy.
big buford
Buena Park, Ca
Posted: 03/22/12 11:15pm Link  |  Print  |  Notify Moderator
If the connections check out good.
Today, I put my charger (which gives me a battery % indicator) on the batteries and after I tried to open my slide outs (they only opened about 5 inches before the "stop and start" started) and it showed my batteries at about 37%
I would have the batteries load tested, Without knowing for sure you have a good set of batteries you'll be chasing your tail.
fuzionhauler
Alaska
Posted: 03/22/12 11:19pm Link  |  Print  |  Notify Moderator
When i bypass the one CB, my batteries stay in the green.
big buford
Buena Park, Ca
Posted: 03/22/12 11:25pm Link  |  Print  |  Notify Moderator
yep just remembered you said that, sounds like a bad breaker
You know somebody with an amp meter that can measure the power draw while operating the slide?
* This post was edited 03/22/12 11:37pm by big buford *
nayther
Burbank, CA
Posted: 03/23/12 08:27am Link  |  Print  |  Notify Moderator
He already changed the CB once, doubt there are two bad ones but you never know. Have you put a volt meter on the system when you try to use it? If the voltage drops a lot when you hit the switch I'd suspect a bad connection/ground or undersized wire. When the voltage drops the amps go up (watts = volts x amps) and that could cause the breaker to trip/reset/trip.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
mobilefleet
on the road
Posted: 03/23/12 10:55am Link  |  Print  |  Notify Moderator
replace the breaker and keep a spare for next time. You don't want to be on a trip and have to mess with that. My bet is it will work great when you install a new one.
fuzionhauler
Alaska
Posted: 03/23/12 11:23am Link  |  Print  |  Notify Moderator
I'll try the breaker again..if that doesn't fix it, I'm stumped!
Dirtclods
Newport Beach
Posted: 03/23/12 02:31pm Link  |  Print  |  Notify Moderator
Just guessing here but what trigger's the slides outs to stop? That could be your problem too?
