RV.Net Open Roads Forum: Truck Campers: Sine Wave Inverter Help
 > Sine Wave Inverter Help
Page of 5
camperpaul
Wherever I park my travel trailer
Posted: 03/23/12 10:43am Link  |  Print  |  Notify Moderator
Reddog1 wrote:
Perhaps I am just too much overkill with my #4 battery cables, but in comparison those cables sure look small.
Wayne
IMO #4 is too small.
1. Use the largest practical wire size.
2. Use the shortest practical wire length.
3. DO NOT coil up the excess wire; its a fire waiting to happen.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
tkcrawford
Edmonton, Alberta
Posted: 03/23/12 11:03am Link  |  Print  |  Notify Moderator
Wayne
I agree those cable look way too small for a 3000 watt inverter. Go Power recommends 4/0 gauge wire with a 400 amp fuse for their 3000 watt inverter.
Just last week I installed a Xantrex Prowatt SW 1000W inverter and used 1 gauge welding cable for power, routed through a 1000 amp disconnect switch and a 150 amp auto-resetting circuit breaker.
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600
2008 Eagle Cap 995
bigfootford
Fair Oaks, California
Posted: 03/23/12 11:09am Link  |  Print  |  Notify Moderator
Wayne
Ditto this..Not even overkill if 300watts is needed for output of that
Inverter...
Figure 10 Dc amps for each 100 watts needed..
300watts = 30 amps... = 6 ga wire for a 5 ft run...
Edited for correct ga wire..Jim
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
If you do not need 300 watts then under fuse the Dc...Then smaller wire is ok.
100 watts would be an 8 ga wire fused at 10-15 amps.
Jim
* This post was edited 03/23/12 03:01pm by bigfootford *
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bigfootford
Posted: 03/23/12 11:10am Link  |  Print  |  Notify Moderator
tkcrawford wrote:
Wayne
The converter in the picture is 300Watts
Jim
bigfootford
Posted: 03/23/12 11:32am Link  |  Print  |  Notify Moderator
DiscoChicken wrote:
Looking for a Pure Sine Wave inverter to push my Samsung 22" TV and Mac Mini computer. Any suggestions? TV needs 45 Watts Mac Mini 85 Watts.
Where is the best place to get the DC power from? Directly from Battery? It would be nice to have it cut off like everything else with the battery disconnect.
Thanks for your help.
I have a small 100 watt inverter...for my tv/dvd. Permanently mounted.
I have it fused and a cutoff switch for the source dc to the inverter.
I have a master cutoff switch for my battery. The inverter is connected to it so if the master is off everything is off including the inverter. I only turn the switch on for the inverter when I need it.
I do have a nice small portable, Modified Sine wave, 75watt inverter that I use for my laptop. Plugs into a cigarette lighter. Used that for years...A Mac may not like a Modified Sine wave inverter so you might need a Pure Sine Wave, either way.
My laptop running on the inverter pulls about 4-4.5 amps max. That is max 54 watts dc...and about 60watts output from the inverter.
Thus not pushing it very much.
Some folks will run an inverter and wire it into the bottom or top socket of their Rigs 120vac system. I elected not to do that. I only wanted to run my tv/dvd/vcr....so I just ran an extension cord from the inverter to a small power strip near the tv and peripherals.
Jim
Mello Mike
Mesa, AZ
Posted: 03/23/12 11:34am Link  |  Print  |  Notify Moderator
smkettner wrote:
The 100a fuse on the 12v side seems kinda big.
The installation instructions actually called for a 110 amp T style fuse, but all I could only find was a 100 amp fuse. For the wire size, amperage, and length of the wire run, 100 amps works.
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
bigfootford
Posted: 03/23/12 11:37am Link  |  Print  |  Notify Moderator
You are right it will work...But...
Jim
smkettner
Posted: 03/23/12 11:46am Link  |  Print  |  Notify Moderator
110 to 400a class T
http://www.bestconverter.com/Inverter-Class-T-Fuses_c_129.html
675 watts solar
clinthia
Flathead County, Montana
Posted: 03/23/12 11:48am Link  |  Print  |  Notify Moderator
tkcrawford wrote:
Wayne
I'm guessing you're referring to my setup. The inverter to batteries cables came with the inverter and it is a 300w not 3000w inverter.
Hope this clears things up, Clint
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
tkcrawford
Edmonton, Alberta
Posted: 03/23/12 11:50am Link  |  Print  |  Notify Moderator
bigfootford wrote:
tkcrawford wrote:
Wayne
Jim
Yes, you are correct. My apologies...old eyes.
Page of 5
