RV.Net Open Roads Forum: Tow Vehicles: Cracked injector line on 5.9 CTD
Search only in Tow Vehicles
 > Cracked injector line on 5.9 CTD
Old-Biscuit
Across the USA
Posted: 03/27/12 11:09am Link  |  Print  |  Notify Moderator
Perrysburg Dodgeboy wrote:
esfd243 wrote:
Is the water pump worth replacing as general maintenance? I have 83k on my 5.9
I have 126K+ and still running the stock pump.
Not sure what "special coolant" Biscuit is talking about, any 100/150K mileage rated coolant will work as long as it has this label, from Prestone. "Prestone® Extended Life Antifreeze/Coolant is compatible with ANY antifreeze/ coolant – regardless of color – for use in ALL makes and models of cars and light duty trucks. This patented formula provides a high degree of performance durability and carefully balanced protection against temperature extremes and rust corrosion of all cooling system metals, including aluminum."
Now the Dex-Cool is a horse on a different color. If you have a GM that uses Dex-Cool you had better use it and only it!
Don
HOAT/GO-5 as per owners manual.......couldn't find ANY antifreeze/any brand that stated compatible with HOAT coolant. And as I was topping off after water pump replacement......HOAT was what was in engine and what was going back in. Just tough to locate on a Sunday in lower S/W Alabama.
gorjo01
Eastern Ontario
Happened to me last year, found out AFTER it was a common problem and injector lines should be checked regularly for looseness and possible rubbing.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 03/27/12 11:24am Link  |  Print  |  Notify Moderator
That's a good question Biscuit and I called Prestone's tech line left them a message asking if their anti-freeze is compatible and can be used with a Ram/Cummins truck. Will let you know what I find out.
BTW I would use the blue "Tight" loc-tight on bolts so you can remove the bolt when needed.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
Dave Wilburn
Ogden UT
Posted: 03/27/12 01:14pm Link  |  Print  |  Notify Moderator
The new line will come with a new bracket and a different hold down. It will fix the problem.
If you have the stock one, put a wrench on it every oil change and make sure its still tight.
04.5 Ram 3500, '12 Voltage 3905 Epic, 69 baja bug
ib516
Up here!
Posted: 03/27/12 01:34pm Link  |  Print  |  Notify Moderator
canoe on top wrote:
Thanks for the replies. Guess I better have a look at my water pump as well?
Mine has almost 5000 hours on it, still original. If it does fail, it takes all of 15 min to replace, and uses 2 10mm bolts. The part is about $30.
On the fuel injector line, I think (but not sure) in later designs this was changed. Mine has blue plastic insulators at the hold down locations, mine has never been loose.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
#40Fan
Colorado
Posted: 03/27/12 09:37pm Link  |  Print  |  Notify Moderator
I do believe the older isolators were red. But, I'd have to look tomorrow to find out.
2005 Keystone Outback Sydney 31RQS
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
dadwolf2
Henderson,NV
Posted: 03/28/12 05:37pm Link  |  Print  |  Notify Moderator
My 05 has the blue plastic insulators on it.
Suppose I should get a water pump and put it in my emergency kit
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
