RV.Net Open Roads Forum: Class C Motorhomes: Tires and wheels
 > Tires and wheels
Cruisineasy
Hayward
Posted: 03/23/12 12:27pm Link  |  Print  |  Notify Moderator
I have another question,
I have a '11 31' Greyhawk. I'm looking to buy a spare tire and wheel. The tires are LT 225/75 R16. The duals are reversed. (inside and outside) is it a different rim for each?? How about the front?? Might be a dumb question....
Thanks
Dave
j-d
Sunny Florida USA
Posted: 03/23/12 12:36pm Link  |  Print  |  Notify Moderator
If it has steel wheels, all six are identical, so a matching spare will serve all. The fronts and inner duals are mounted one way and the outer duals are mounted the other way, but they are the same. If you happen to have aluminum wheels, the set is usually only four wheels. They'd be on the front and the outer duals, and the inner duals would be steel wheels. But same spare'd still work.
No problem there. Getting access to check tire pressure, perhaps. Search "valve stems", "tire valves" etc. and there's lots of discussion.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
DaCrema
Va
Posted: 03/23/12 06:16pm Link  |  Print  |  Notify Moderator
As I thought, thank you
oldtrucker63
Harlan Kentucky
Posted: 03/23/12 06:48pm Link  |  Print  |  Notify Moderator
Yes all the same, Steel or not they will run together, No Problem at all.
Without Trucks,....America Stop's
DaCrema
Va
Posted: 03/23/12 02:07pm Link  |  Print  |  Notify Moderator
Are there issues mounting aluminum wheels next to steel wheels in the rear. For example the different ways the two types of metal handle heat, or electrolytic action messing up the wheels? I am new at this but have always liked custom (lighter) wheels on my cars.
Dakzuki
Carnation, Wa, USA
Posted: 03/23/12 04:13pm Link  |  Print  |  Notify Moderator
On some RVs if you order the extra aluminum wheels you only get 4. The inside rear wheels will still be steel ones. Putting a steel wheel next to an aluminum one is no worse than mounting an aluminum wheel to a steel hub.
2011 Itasca Navion 24J
95 Chinook Premier
 > Tires and wheels
